Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Westell 327W & Verizon DSL
Can I configure this device to connect remotely as VPN setup? I have Verizon DSL and this is the DSL modem they provided.
  • kcbailey_1 Oct 06, 2008
    I have centrytell wireless and Westell Model 327W
Same problem here. No permanent fix but if I set the security level to "low" I can connect. Annoying but less annoying than driving into work.
Posted on Oct 15, 2008
I have centrytel DSL and westell Model 327W
Posted on Oct 06, 2008
I have Verizon DSL service on my Westell 327w. It
whenever the connection drops, is the DSL light blinking?
because, it is just normal for the E1 light to blink, but the DSL light should be solid at all times.
It can be a possible issue with the cable or the LAN card, but you still need to have your line checked by Verizon to make sure that it is not a modem or a network issue.
Feb 21, 2010 | Westell Wirespeed VersaLink...
Switching from a verizon 6100 dsl modem to a 327w versalink
make sure that your old setup not still on go to connect to from the start and right click on the connection and see the one that you are using is present
Nov 08, 2009 | Westell Wirespeed VersaLink...
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Oct 07, 2009 | Westell Wirespeed VersaLink...
Cannot get PPTP VPN to connect via Westell 327W (Verizon DSL)
Is the VPN server that you are trying to connect behind a firewall?
Jul 18, 2009 | Westell Wirespeed VersaLink...
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
Mar 29, 2009 | Westell Wirespeed VersaLink...
I configured my verizon westell 327W to connect to the internet using an ATT FastAccess DSL connection but when the IE window comes up - i get the verizon activation startup page - how do i get around...
You most likely have to call and setup you mac address with your ISP. There is really no way around this is your ISP requires your MAC address. This is located on your modem. Give them a call and tell them the MAC Address of the Moden and you should be good to go.
Jan 15, 2009 | Westell Wirespeed VersaLink...
Hi I can only use the Westell 327W with DSL
This Westell 327W can only be use with a DSL internet connection since this is a DSL modem..
Hope that helps.........
Sep 19, 2008 | Westell Wirespeed VersaLink...
Westell 327w
xbox live connection test MTU failed
Mar 12, 2008 | Microsoft Xbox 360 Console
VPN through Westell Versalink 327w
do you have login access into the Modem/Router?
if yes, look for port forwarding and set it to your IP of your computer. open port 500 or what ever is required by MS fro the VPN
Nov 01, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
348 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
