Question about Whirlpool Duet GHW9150P Front Load Washer
Not draining or spinning
I had washed a blanket which fell apart so have cleaned a lot of fluff etc from filter but It now stops halfway through wash cycle while still filled with water. Any ideas please?
    Novelist:
    Champion:
  • 261 Answers
If it stops when the machine is trying to balance before a spin and get a F 21 or similiar error you will need to do a radical pump cleanout and flush it. After access is gained get a large paint tray or better yet if the machine is on a pedestal use a mop bucket. for the bucket or tray I will either slide the pump out or on some loosen a torx screw at the front base and pull it forward enough to position over a bucket along with some towels and dont worry about the wire harness it will bend down. When drained look in the hole that leads to the impeller on the pump and check for blockage and try to turn it with a finger because if it is loose you need a new pump.Try tapping and squeezing the bellows behind the trap and finally examine all with a flashlight then run the machine on a rinse spin to and check for leaks. NOTE: If water doesn't pump after this and the pump just hums,.. replace it.
Posted on Sep 10, 2008
Miele W1918 washing machine question:
Check the rotor again very carefully - something like a pin or piece of grit, a nylon tag or piece of wood that floats clear can be very hard to spot. Can you turn the water pump rotor manually with something like a long screwdriver, or is it stuck? Will need a replacement if seized as freeing it will only fail again. Some coins or 'Tazzos' - ie kids toys / counters can flip on edge and completely block a hose under the 'right' conditions.
Are you sure the drain tube is clear at its connection with the waste pipe / sink trap? Another possibility is a sock or pants stuck in the sump hose completely blocking it - or have you washed the dogs blanket or bathmat etc that has shed fibres blocking the sump.
Feb 03, 2018 | Miele Washing Machines
After washes it displays check detergent. some washes are also not spinning properly and cloths are still quite wet. Can you help I have a miele gala grande w 3000
Hi dear.
Basically you can check fluff filter otherwise you may need to have a technical assist. Fluff filter located on front LHS bottom corner of your machine.. Open plastic cover. Place small bowl under fluff filter area to collect about 2 Lt of water. Slowly turn fluff filter anticlockwise to let it drain remaining water in there.. Then remove it and check for blockage. ( Step by step You can get full instruction from your machine's user manual on cleaning and care section.) If that does not solve the issue you may call Miele to assist you or local repairer. I hope that helps.Thanks.
Jan 16, 2016 | Miele Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
I would just like to know where the filter is on a top loading speedqueen washing machine. there must be somewhere that the bits and fluff collect.
there is no filter' it's what they call a self cleaning lint filter, collects lint while washing and then on spin lint goes out with the drain water
Feb 18, 2011 | Washing Machines
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Wash machine says E3
not sure where you can get a manual but sometimes blankets produce a lot of fluff while washing maybe the pump filter needs cleaning out the machine will not reach speed with too much water in it
Nov 11, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Bosch Maxx Classic water drain problem
you only need to check the filter once a month or so depending on what you wash - blankets for example give off a lot of fluff. to help prevent water spilling out when you check, put machine on drain and check filter while draining.
Jul 15, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Spins very slow on rinse/drain and spin
Your filter &/or pump could be blocked. Remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter & clean out. Refit. If you have manual refer to it. Pl rate me if helped.
Jan 20, 2008 | Kenmore 46462 Front Load Washer
Intermittent wash cycle
If there is a filter on this model, make sure it is clean, a lot of fluff and other stuff can accumulate in the filter preventing the water from draining fast enough. Sometimes the pump can get blocked with the same effect. Tom.
Feb 26, 2007 | Haier XQG50-QF80 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
