Question about Logitech (980174-0914) Consumer Headset
Broke earpiece the earpiece on my headset fell off but now i would like to hook it up to a small speaker, how can i do this so i hear from the speaker but talk through the mic still
  • 513 Answers
It's doable, but you might wan't to consider buying a stand alone mic, they come pretty cheap. What you need is a speaker with internal amp, and a new pl jack - you cant just patch it into the wire that went into your earpiece, its a different kind of wire. When you go to radio shack or equivalent to get the jack, ask them to show you what kind and exactly how to go about it. Not very complicated, but maybe unnecessary. Good luck
Posted on Mar 16, 2006
My samsung WEP650 bluetooth earpieces audio is not working. I am able to talk and the other party can hear me but I can not hear anything on my end. Any suggestions?
From your explanation, audio (microphone) is working: instead, speaker isn't working.
Have a phone/electronics service technician help check your Bluetooth earpiece out.
Speaker connection cable is disconnected (internally).
Otherwise, the speaker has defects and must be replaced.
A last resort may mean the Bluetooth headset board is bad.
Oct 11, 2017 | Samsung Cell Phones
My LG KM555E phone is not working well, I can't hear any call any txt without using headset. The speaker is not working.
You will need to open the phone to get access to the board so as to check on the earpiece. Now it is confirmed that the earpiece is faulty and the board is working perfectly as the external headphone is used with good result . So using a multimeter check the continuity of the small speaker, remove and check. If resistance is open then the earpiece has failed. If not the sensitivity has dropped. make sure there are no blocks on the earpiece to prevent sound.
Apr 08, 2011 | LG Cell Phones
Can hear caller on speaker on but not on headset. when someone calls and i answer i cannot hear them on the headset only on speaker. voice volume is all the way up.
The headset speaker is faulty, the earpiece.
So open the phone and make a audio test on the earpiece , If the sensitivity is low the earpiece speaker is faulty.
replace or try with a salvaged on frrom an old phone. Now you are confirmed. If not there can be issues in the board, the preamplifier.
Sep 20, 2010 | AT&T LG CU515 Cell Phone - Black
During a call, i cannot hear anything when using the handset of my phone that's why I need to shift it to loudspeaker in order to hear the voice of the person i'm talking to.
The faulty might comes from your earpiece(small speaker) or from its track or missing track.But first check if your phone shown some symbol.If symbol like headset without connecting handsfree the problem comes from charging connector.First You have to do is just clean the pcb.the tips of earpiece.
Aug 21, 2010 | Cell Phones
I cant hear anything on my nokia 6500s expect on speaker
The problem with your phone is the earpiece, since you have adjusted and try increase the volume, yet, same problem. The earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Replace the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Aug 09, 2010 | Nokia 6500 Slide Cellular Phone
My orange env1 is reacting as if I have an headset in it and when people call me I can't hear them and they can't hear me but if I hook up to the headset that is the only way I can call people and talk to...
You are not missing anything, The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Jun 27, 2010 | LG enV VX9900 Cellular Phone
Cannot hear anything on receiving call bt able to hear with speaker on or on hand set......
you have to change your speaker (earpiece)
when you choose the loud speaker option,,
you will able to hear the voice,,why?because the sounds transfer from earpiece to buzzer..its same when you use headset..the sound from earpiece will transfer to headset speakers..in that case,,you need to replace your earpiece..100% your problem will be solve!!
Jun 16, 2010 | Nokia 3110 Cellular Phone
Earpiece not working after hooking it up with a bluetooth speaker
Go to Bluetooth settings and turn on Bluetooth.
The paired devices will be shown.
Delete paired device or unpair device .
This should solve the issue .
Since the mobile is paired with the Bluetooth speaker every time a call comes in the phone automatically connects to the Bluetooth speaker.
Switching off the Bluetooth speaker may also work.
Mar 28, 2017 | Motorola Mobility ROKR E8 Cellular Phone
CS70N Wireless headset
The earpiece will make 3 short beeps when a call is incoming. Also the phone will still ring if you are within distince to hear the ringer. Hope this helps! SM
Sep 10, 2008 | Plantronics CS70 Wireless Headset
Can't hear when the speaker is off
earpiece and speaker are separate so in that case the earpiece is broke and u sould have'it replaced to a cellphone service
Apr 21, 2008 | Motorola Mobility RAZR V3
Logitech (980174-0914) Consumer Headset Logo
79 people viewed this question
Top Logitech Radio Communications Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
