Question about Kenmore Elite 45986 Front Load Washer
White spots on clothes
We are experiencing light colored spots on our clothes that look like small bleached spots. However, we do not use any chlorine bleach, only occassional non-chlorine bleach, like Clorox 2. Any ideas on the cause of this would be appreciated.
  • carmenhays Sep 16, 2008
    I too have white spots appearing on dark clothing. It looks like bleach spot but I rarely use bleach except to do a clean cycle. What is causing this?
  • 126 Answers
YOUR PROBLEM IS ONE OF TWO THINGS.FIRSTLY DEPENDIN HOW OLD THE MACHINE IS THERE COULD BE A BUILD UP OF LIME SCALE AROUND THE DRUM.TO SOLVE THAT YOU NEED TO PROGRAM YOUR MACHINE ON A HOT WASH AND LET IT RUN EMPTY TILL THE END OF THE CYCLE.SECONDLY YOUR SOAP POWDER MIGHT NOT BE DESOLVING PROPERLY.YOU MIGHT NEED TO DISSOLVE IT AND MAKE IT LIKE A WATER PASTE BEFORE INSERTING IT INTO THE MACHINE.GOOD LUCK.MOHAMED
Posted on Sep 10, 2008
Remove bleach stains
For an immediate treatment of a bleach stain, try Sodium Thiosulfate (often referred to as photographic fixer, it is an agent that has been used as a way to neutralize bleaching effects of other substances. Blot stain at first with a white cloth that has been dipped in ST until stain begins to disappear of fabric becomes saturated. Rinse with cold water and repeat until desired effect or no more progress has been made.
If you wanna get rid of the stain without using laboratory grade chemicals, use white vinegar. Before this, make sure you rinsed bleach out of fabric, if you don't it will release a toxic chlorine gas.
Soak a clean white cloth with vinegar and start blotting stain, keep doing this until fabric won't hold anymore.
Apr 03, 2014 | Clothing
I just viewed a bunch of complaints about chlorine bleach getting dumped on the subsequent load, but did not see a true root cause response. 1st question: When you use chlorine bleach with the whitest...
chlorine bleach is a highly corrosive addition to laundry that is not necessary... try Borax and Hot water. If the clothes sat in the Bleach for the entire wash cycle it would damage them and shorten the life of the clothing fibers considerably...
Apr 21, 2017 | Whirlpool GHW9400 Front Load Washer
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I just need someone to explain to me if I should add clorox bleach. and clorox ll in the same area, but not at the same time. I don't understand if you should add them into the same area it seems as...
When you add bleach to the beach dispenser, it goes directly into the water in the outer tub, where it dilutes, before coming into contact with your clothing. I'm no chemist, but I think the difference between the regular bleach and the "color safe" bleach is either a chemical additive, or just a special dilution.
If it's the latter, mixing the two will add too much chlorine, and "bleach stain" your colors. Follw the directions on the bottles, and also the user guide that came with your machine, if you still have it.
Dec 30, 2010 | Kenmore Washing Machines
Clean clothes that smell bad
Peace,
ngafm at your service!
You may have a small amount of water or lint lift in the machine somewhere that is not completely dumping out !
This is sometimes common on front loaders! Or the pump is weak!
I tell my customers to try running the washer without clothes once a week with hot water and a 1/4 cup of bleach!
. BUT the first load you do after this must be white in case there is a drop of bleach left in the system, that it does not spot bleach a white spot on your colored clothes!
If not this does not remedy the situation you will need hands on service!
please rate me here at our site before you sign off!
Thank You!
Sep 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
White spots on color clothes
try using calgon tablets, they flush out washing machine for limescale, perhaps it will work for you
Jul 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
185 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
