After many faults my monitor is not receiving signal from my computer
  • 320 Answers
Unplug your VGA cable and Switch on the monitor. It Should display a message that Cable is not plugged in like. If that message comes then monitor is alright. Once again plug and check the VGA cable of your monitor. If it works than its ok. Otherwise there is a problem in your display card which is present in the motherboard. You can insert an new display card or graphic card into your motherboard. Thank you.
Posted on Sep 09, 2008
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Mar 27, 2013 | Computers & Internet
Computer monitors led flashing green and no signal to my pc
to start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitoror computer fault.if it is computer fault and no video signal ,then test
-video cable
-video adapter on pc (sometimes integrated on motherboard).
Aug 16, 2011 | Computers & Internet
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Compaq montior FS7600 turns on but orange light only lights up and it doesn't go to green. Screen never turns on.
This may not be the monitor at fault; if it isn't receiving synchronization signals from the video card or circuit, this is also how it may act. Try disconnecting it from the computer; if it brings up any kind of screen message, the monitor is OK but not receiving video. If possible, borrow a monitor and try it with your computer to ensure that the computer is supplying signal at all.
Mar 24, 2011 | Computers & Internet
Check signal cable
There is no problem. The monitor is telling you that it's not receiving a signal. The reason there is no signal is because your computer is turned off, so it's telling the truth. :D
The monitor should go into idle mode on its own, so you won't see that message for very long. It's annoying, but doesn't cause any real problems. You can save even more energy by shutting off your monitor entirely after you shut down your computer. This will make the message go away and also save money on your electricity bill!
Apr 23, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
My monitor receives power, but doesn't receive signal from my computer. The green light blinks like there is something wrong and there is a faint beeping noise.
1st you separate you monitor from you Computer.
  • Now On your Monitor and check there is Faint beeping noise.
  • If there is no noise and after sometime the monitor light will change in orange colour.
  • It means there is no fault in monitor.
  • And also check Data cable of monitor is it right.
  • It means there is problem with you computer .
  • You Check the VGA Card.
  • I think there is problem with your VGA Card.
Mar 10, 2010 | Acer AL1916W 19" LCD Monitor
The monitor starts up displaying no signal
This means that the monitor is not receiving a video signal from the computer. When it doesn't receive a signal, it goes to sleep. You should check to make sure that the video cable is tightly connected, and also, if you have another monitor around, connect the other monitor to the computer and see if it works. It's possible that your monitor has malfunctioned.
Mar 03, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
The LED on my monitor is yellow, and the picture is solid black...what does that mean?
It can mean that the monitor is not receiving the signal from PC, or the fault can be in the monitor itself. Try the monitor on the other PC to see if it does the same, then post back so we can guide you further.
Feb 26, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Acer Monitor Doesn't Receive Signal From Computer
can you test your monitor on another computer to verify the monitor is at fault? If the monitor is at fault its time for a new one, factory warranties on monitors are usually 1 year unless you purchased an extended warranty.Otherwise repair is usually more costly than buying a new one.
Dec 25, 2007 | Acer 17" AL1706B LCD Monitor
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
