Question about U-Line Icemaker
Ice bucket/bin frozen in place
My u-line ice maker seems to supply too much water to the ice trays, as when the unit has started to freeze, there is a 1/2 sheet of ice on the bottom of the ice tray/bin, and the tray/bin can't be removed until the unit is turned off and defrosted. The unit works great except for the overfilling (?) problem. Is they're a regulator to deliver less water to the ice fillers?
Thank you so much
john milam johnmilam@mac.com
    Problem Solver:
Mine was overfilling because the ice was getting stuck on the way out. So some stayed in the tray and when the water would refil, it would overfil and go over the stuk cubes. leaving it to overflow to the bottom and freeze like yours.
Posted on Sep 17, 2008
We have a Samsung RF4287HARS french door refrigerator. The ice maker seemed to not be working properly and I tried to pull out the ice bucket and it will not budge. Any suggestions as to why we can't...
I would suggest that the ice bucket has water around the base and that has frozen the bucket bin place . If you can, try filling the bucket with hot water to loosen the ice around the base.
Feb 11, 2015 | Samsung Refrigerators
Hss25gfta refridgerator ice maker seems to be stuck on off .It all of the sudden quit making ice and we can't find the solution.It makes water fine
Hi and welcome to FixYa I am Kelly.
The ice maker suddenly no longer making ice can be caused by many things.
1. The freezer section is above 16 F.
a. Usually the cause is ice buildup on the evaporator coils as a result of an automatic defrosting problem.
b. The evaporator fan is not turning at full speed
2. The ice makers thermostat has failed. When the tray reaches 16F temp is closes the circuit and starts the ice maker harvest cycle.
3. The ice maker drive motor has failed.
4. The ice maker heating element has failed.
5. The inlet water valve is allowing water to drip into the ice tray during the freeze period of ice making.
a. You would note that the water fill area of the icemaker would have ice build up. Also in the very back of the ice make tray ice would build up and prevent the sweep fingers from rotating.
b. Usually when the above happens the rubber water inlet tub that goes from the back of the unit to the ice maker is frozen solid internally.
c. You can test this by removing the plastic hose from the rear top area of the unit and placing the upper end of the tub in a bucket for several hours. (ICE MAKER OFF) If you note water in the bucket the water valve is leaking water past the diaphram when the solenoid is supposed to be closed and must be replaced
6. The inlet water valve solenoid coil has failed.
Most appliance parts sources do not sell piece parts for this ice maker. They only sell the complete assembly. Here is one source of many on line sources for just the icemaker.
http://www.appliancepartspros.com/part_details.aspx?part_id=4345120
Should the water valve be leaking water by it is item 800 of this link that is also one source of many online sources: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Thanks for choosing FixYa.
Kelly
Sep 03, 2010 | Hotpoint Refrigerators
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
RS 2545SH ICEMAKER
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 22, 2010 | Samsung Refrigerators
Ice maker does not make ice. Water supply works, but ice machine is dry.
if it is the ice maker in the door, it's a bad ice maker....we do a lot of them
Nov 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker in refridgerator freezer won't make ice. It seems as if the water is going up into the freezer but no Ice is being produced. The ice tray has frozen ice in it, but it will not dump it in the ice...
Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
Oct 16, 2009 | Kenmore 50522 / 50524 Side by Side...
My ice maker wont make ice the water is not going in the tray
First, make sure the arm on the ice maker not in the up (off) position.
Second, pull out the refrigerator from the wall and make sure there is no crimp in the line from the wall.
Third, check that ice is not frozen around the plastic teeth. Pull out the whole ice bucket and thoroughly check that something is not blocking or frozen in the wrong place.
This will get you started.
Jul 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
U-Line Icemaker Logo
271 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
