Question about Ricoh Aficio 1013F Copier
1018 am having a functional problem 302, what is the cause?
  • Ricoh Master
  • 2,794 Answers
If it's an SC302 it has to do with the Charge Corona output error 3.
Grid voltage error
Charge voltage leak.
This needs to be looked at by a technician to either clean or replace the corona wire or see if there is power problem going on.
Posted on Sep 09, 2008
How could I solve sc 302
sc 302 cause dirty copy, if u see the dram it is dotted, replace dram or charging roller..
Sep 25, 2014 | Ricoh Office Equipment & Supplies
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
In a 1018 machine i have an SC 194 code- functional problem
Normally one of these two problems.
Exposure lamp defective
• Dirty white plate
If the lamp comes on, take the glass out and clean the mirrors and glass well, Turn the glass upside down and clean the white reference areas well. That normally causes a SC-194
May 20, 2011 | Ricoh Aficio 1018D Copier
Sc 302 - charge roller current leak.aficio 1018
Replace the PCU assy (drum unit) or a service call to rebuild the unit, sorry...-Carl
Nov 01, 2010 | Ricoh Aficio MP 2000 Black and White...
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Functional Problem SC 302
SC 302 has to do with you charge corona wire.  It's unrelated to the toner spill.  It could be a bad conora wire.  Sometimes it's the power supply.  There could be a lot of troubleshooting and repair to do on this one, you might want to contact a dealer in your area since the have the right tools for the right job.
Sep 30, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Nov 30, 2007 | Office Equipment & Supplies
122 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
