Need a signal board, new or used for Mitsubishi WS6580952 part #930B88101
Ive learned a bit about this model in a day, as my nieghbor bought a new Sony and gave me this one. The repair shop was going to charge $600 for the board but then couldn't come up with one. I didnt find a board but did buy two more Mits 65 s both for $750 and one of them almost like new. I have the first one about back together as it appeared had leaked coolant fluid on signal board. I cleaned with alcohol and think it might. I like the picture they have so I would still buy a board if could find one. And will try to make two of three last a few more years or all of them looks like would be pressing my luck. I think I could part one of them out and pay for the other two. Let me know if you think we should have a visit as I am by no means an electronics wizard. I used to be a race car builder, so they could possibly end up with wheels on em. Thx for the come back have a good one.
Posted on Sep 10, 2008
Where can I get a Mitsubishi Signal Board 930b881001 New or repaired
boards for these sets are never available any more from Mitsubishi----google PTS---they repair, rebuild all kinds of circuit boards.
Aug 06, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WS65807
The Color Signal on this Model Series travels across three boards before being sent to the CRTs. The 3DYC Board, Signal Board and the Terminal Board. Most likely, the 3DYC Board or the Signal Board is causing the problem. I have had intermittent solder connections on the 3DYC Board to cause no color problems. This Board plugs in and is located on the left front of the Signal Board as you look from the rear of the chassis. If you feel you are not up to the task to work on the set, call a Mitsubishi professional. To find one, call Mitsubishi at 1800-332-2119.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Need signal board
u can get the require parts at www.partstore.com just insert the proper model and select the perfect brand in the link and the required part will be shown with its present rate.u can also order from this link.
Jan 06, 2009 | Mitsubishi WS-65819 TV
Picture with signal applied is purple and distorted/choppy
The board you seek is the doubler (2HDW) module.. a lot of time reseating the board will solve the issue. If HD still works, this board is likely you problem. This board upconverts all non HD signals to hd to put onto the screen. IF HD doesn't work, you more likely need a signal board. This board has all the settings on it and is much more difficult to replace.
Dec 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
We have a Mitsubishi DLP and the timer light is flashing on and off and I cannot turn the power on or off on the TV
Bad signal board, DM module and or formatter board. Try replacing the signal board first. About 50% of my fixes with flashing timer LED was solved by signal board replacement. If this doesn't work, then try replacing the formatter board. And if still don't work, then DM module must be replaced.
Mitsubishi don't have a real answer behind these failures. I know and I've tried. Do have two of them just came in my possesion for repairs. One has same problem and just put in order for new signal module.
Nov 27, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi ws-55513
Could be signal board issue,not related to DM.Might be terminal
board problem = less $ and easier to sub than signal PCB.......T.
Apr 15, 2008 | Mitsubishi WS-55513 55" Rear Projection...
SIGNAL BOARD
Hi, Any authorized Mitsubishi dealer can order your board for you, If you live in a metro area go to Sears Service dept.(not the stores) and order one there, Mitsubishi is "proprietary parts" so you have to go to an authorized dealer, hope this helps you out, BMW Rider
Jan 14, 2008 | Mitsubishi WS-65819 TV
Dvd plays fine sound/picture...No sound or picture with cable input
John,
To answer your question no, there are no fuses associated with the tuner input - through the "F" connector jack.
You have there a V26 chassis which has, among other things, standard digital and analog signal inputs. If one works but not the other - and you've verified it's not the cable then the only alternative is the signal board, Mitsubishi p/n# 930b923002...
But don't rush out and buy this puppy, it's a fairly expensive board and there are alternatives to replacing it new or used - PTS Electronics can rebuild this board for half the cost of a new one and most techs use PTS for that reason.
My best advice is to have a qualified shop estimate the repair and if they decide that the signal board needs to be replaced and quotes you a price ask them then about having it rebuilt.
Also take the unit to them to save the pickup/delivery charges and ask for your estimate in writing...
Hope this helps!
Bill
Dec 06, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55908 Convergence Issue; need IC 7A00, Panasonic MN12857k MA2
Sorry, but when the coolant leaks down onto the small signal board, that board will never work right again. The fluid penetrates the board itself since the board is double sided and has many feed-throughs. The fluid gets under the surface mount parts and just eats through the copper traces, part leads and board itself. After trying many times to clean and restore those boards, not one has ever worked right again. The boards are NLA from Mitsubishi, so the set is done.
Aug 30, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Electro Med Services...
