Question about Whirlpool Refrigerators
I have a whirlpool multiflow 380lt fridge i have broken some shelving i need the egg guard and crisper box where could i get these parts i live at st marys sydney nsw
  • Whirlpool Master
  • 19,396 Answers
Try contacting Stokes here:
Stokes (Australasia) Limited: Stokes Appliance Parts
24 Palmerston Rd West Ringwood, Victoria 3134 Australia
ACN: 24 004 554 929
Tel: +61-3-9845-8300
Fax: +61-3-9874-1077
E-mail: info@stokes-aus.com.au
Or contact Whirpool:
Whirlpool Service - Parts Price List
call Whirlpool Service on 1300 363344 (Australia) or 0800 442584 (NZ)
Posted on Sep 09, 2008
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is...
check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Dec 11, 2014 | Whirlpool Refrigerators
Power outage and fridge doesnt come back on when power is restored
First make sure there is power to the plug at the wall. If not check the breaker. If power at the plug, the power outage could have been associated with a power surge that killed your refrig.
Mar 21, 2014 | Whirlpool WRF560SMY 19.6 cu. ft. French...
My fridge is leaking water down the back into crisper
The defrost drain is stoppped up. The easiest way to solve this is with a compressed air tank. At the back of the ref. at the bottom you will see a hose leading into a drain pan.Blow the air through the hose and it will unstop the drain.Hope this helps !
Sep 29, 2017 | Whirlpool GT1SHTXM Top Freezer...
My Whirlpool refrigerator (Model ET21GKXHT01) has water on the shelves, in and under the crispers. I can't see where it's coming from. I don't see any plugged hoses. Help!
condensation with collect on any shinny surface,have you put uncovered food in the fridge or left the door open,refilled the fridge with food from the mall,especially veg,or is it very humid at this time.also check door seals for fit all round as an air leak will not help.
Jul 20, 2010 | Whirlpool GD2SHGX Refrigerator
What is causing water to build up inside the refrigerator section? there is water in the crispers and on the shelves.
A condensation problem inside a fridge, normally means either, you are puting uncoverd food /or food that has a high water content (i.e.salads) into the fridge, which may be warmer than the inside temperature of the fridge, hence condensation(leaving the door open too long has the same effect)only remedy is paper towels in bottom of crisper so that salads dont go soggy.and wipe out fridge as often as needed.
Mar 10, 2010 | Whirlpool ES5FHAXS Side by Side...
Broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
Feb 09, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezing eggs in fridge area and freezing produce in crisper
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Samsung RB1955VQ Bottom Freezer...
Water dripping from top of fridge then freezing under crisper's
HII Your drain line is plugged remove evaporator cover and get a hair dryer and remove all the ice built up on the drain line its a hole just below the evaporator..show here the hole is on the left side.Good
Jan 05, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool ED5VHGXML10 Side by Side Door shelves cracked
HI thanks for your question. its the door liner, that's broken, if you can repair with some epoxy puddy, only problem with epoxy puddy , it smells. so the door liner is to be replaced. thanks the appliance doc. please rate my answer. thanks.
Oct 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
160 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
