Question about Alpine CDA-9825 CD Player
Alpine car stereo model #CDA 9825
My daughter got a jump for a dead battery. The CD player now displays ERROR and the radio works off and on. She will be driving and it will shut off and lose all presets, then start again when she starts the car next time.The radio doesn't always shut off when she drives. The radio was in the car when we bought it, with no owner's manual. Any thoughts? Is the fuse located just behind the radio? Thank you for any assistance. Terry
  • 2 more comments
  • Roofis Sep 09, 2008
    Is there a troubleshoot guide for the error display for the CD player?
    Sorry, only the radio plays intermittently. The CD player does not play at all, and will not eject the disc that is in it.
  • Roofis Sep 10, 2008
    Unplugged battery cable, no change occured.
  • Roofis Sep 11, 2008
    Thanks for the link for the owner's manual. Found the location for the reset button. Hit the reset button, CD player works fine. Great site.
    Brigadier General:
  • 6,966 Answers
Based on your post/description, your concerns are:
  • CD player ERROR;
  • intermittent radio;
  • all presets lost when radio shutdowns.
All of the above indicates a wiring problem or at the very least a loose connection more particularly to the mains B+ (always on) which is often tapped at the IGN SW or on the radio fuse in the fuse box/bank. The always on B+12 is directly tied to the + battery terminal and as the name implies, with or without the key in the IGN SW, there is a +12 always. This always on B+12 is responsible for the retention of the memory presets. Pls re-check that the following wires are connected as indicated:
  • Yellow (with the filter/fuse) - always on B+12
  • Red - ACC +12 (ignition switch)
  • Black - car body ground/negative
  • Blue - to power a motorized/amplified antenna (if needed)
  • Blue/White - to power an external amplifier (if used)
Check/diagnostic procedure for the radio:
  • with the use of a DVM, measure/monitor the voltage at the yellow wire;
  • move the various connectors under the dash around;
  • snap/unsnap the connectors;
  • force/apply pressure to joints;
  • tug on the harness a bit;
  • pay particular attention to the connector going to the IGN SW;
  • while any of the above is being done, the 12VDC reading on the yellow wire should not vary. At any point, on any step/test performed that the reading would deviate (no matter how small) indicates a strongly possible loose/problematic connection;
  • the same could be done with the red wire.
Check/diagnostic procedure for the CD player:
  • soon as the radio's problem has been identified and corrected, try again to eject the CD;
  • if a no-go, you may have to force the disc out using a tweezer;
  • otherwise, the unit has to be opened up.
Additionally, if I may inquire, year, make and model of the car it was installed in.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 11, 2008
    President:
  • 1,450 Answers
Fuse is good if it still comes on. They did not hook cables up wrong did they? check battery connections and see if someone ran a wire to battery for the radio if so cables may have disturbed this and causing bad connection.
    Genius:
  • 1,239 Answers
Hi sir...   please dieassemble the cd - player  and check whether any wire is in loose connection .. and by visual there is no problem. by that way insert the battery and check it is working or not..if also not work's mean's take the multi meter to check the voltage of the battery and see till where the supply pass see at the speaker point how much voltage come's  if at the rate ot 1 to 1.5 vg.. it is correct..     if any assist i am there to solve. thank u .. don't forget to fix it..
Posted on Sep 10, 2008
    Sergeant:
    Champion:
  • 214 Answers
Check the battery cable and also the internal wiring
  • 157 Answers
If the CD player is turning off intermittently, there is a big chance that there is a loose wire or connection inside.
If you can get your hands on a service manual to check connections to diagnose problem, that would be great.
    Master:
  • 726 Answers
You will have to take the cd player out the connector in the back is loose not cliped in good or it might have a loose earth or power wire in will be just a quincidence it happened when it just started it
  • chris07551 Sep 11, 2008
    the reset button should be under the face is that a fixya or what baby yeh
    Master:
  • 763 Answers
Wirings and connection may trouble the function of your car stereo. an expert technician will solve this problem for they were can set the wirings from it. dont relay on my answer if not the wirings is concern. we have a car and deffinitely we send it to a wiring technician if we got a problem about it.
see if your car stereo is a front panel removable and try to locate the fuse. you can buy some fuse from an electronic shop. hope that helps sir
or maybe try this site.
http://www.ehow.com/how_2048981_troubleshoot-car-stereo-speakers.html?ref=fuel&utm_source=yahoo&utm_medium=ssp&utm_campaign=yssp_art
CHARCOIS
Posted on Sep 09, 2008
  • Alpine Master
  • 19,396 Answers
Unplug battery cable for ten minutes and plug it back.
  • Ginko
    Ginko Sep 10, 2008
    Check also all connections at the back, a short in the connector can cause the stereo behaving erratically.
  • 2,296 Answers
If the CD player works intermittently, the fuse is good but there could be a loose wire connecting to the CD player since it's aftermarket. I would suggest to check the red wire and the orange/yellow and make sure they're connected properly. In order to do this. you will need to dismount the CD player and secure the wires mentioned.
  • 2 more comments
  • Jaime Hernandez Sep 09, 2008
    Click here to download the user's guide. Page # 33 will have the errors code listed and page # 38 will have the wiring connections.
    Page # 5 will have instructions on how to reset the CD player and hopefully that might eject the CD after pressing the reset switch. For the radio intermittent operation, I still suggest to check the power wires connected to the device.
  • Jaime Hernandez Sep 11, 2008
    Would you please rate the solution that solved your problem?
    Thank you.
    Sergeant:
    Champion:
  • 331 Answers
You could remove the radio from the socket..............
yes maybe the fuse fot blown
but then it wont work at any time
my guess is that may be some internal wire got burnt
How do i tern the fan off and on or is it automatic
automatic. aftermarket radios have small built in amplifiers and the fans are there to keep them cool
Sep 24, 2011 | Alpine CDA-9825 CD Player
THE STEREO CODE FOR ASN ALPINE CDA 9855? HOW OR WHERE DO i GET IT??
there is no code for an alpine cda 9885. what seems to be the problem with the radio?
Jan 03, 2011 | Alpine CDA-9885 CD Player
When I turn Cd player or car off then back on the Cd player no longer has any of my settings saved
its because your yellow wire isnt connected straight to the battery it would probably be connected to switched connect it to the battery and it will fix the prob
rate pls
Aug 17, 2010 | Alpine CDA-9825 CD Player
Stereo sounds stops but stereo stays on
This is due to a short in one of the speakers Or a blown speaker making it short out and stereo will stopped outputting any sound to prevent damage to the stereo.
Jul 30, 2010 | Alpine CDA-9825 CD Player
I am hooking up the stereo and I know I have power coming to the wires cause the black and yellow ones spark but when I hook them to the stereo I don't get any power
The yellow wire is the constant wire, you need to find the battery + wire which will be red and hooked that to your deck, the red wire is the main 12v wire and the yellow wire is there just to use a little bit of power to keep the memory i yur deck, i.e. the time, cd position stuff like that
May 19, 2010 | Alpine CDA-9825 CD Player
I have a Alpine CDA 7892 CD head unit I just installed and the radio works perfect but when I play a cd it sounds very muffled and I can hear bass only. Is the unit bad?
If the sound is coming out clearly with the radio on, then there is a problem with the cd drive or its connections. If your stereo has aux. inputs, you could run an mp3 player until your ready to replace it.
Apr 12, 2010 | Alpine CDA-7998 CD Player
Battery went dead alpine cd stop working
Sometimes when you jump off a truck the CD player fuse will blow because it was trying to turn on each time you turned over the engine. Check all the fuses.
Mar 22, 2009 | Alpine CDA-7892 CD Player
Alpine CDA 9825, wife hit a series of buttons, now I only see what is on the display when I change a station or turn vehicle on. How do I get the text back on the display?
i would suggest unplugging the wiring harness from the back of the alpine terminal (you will need to basically take out your stereo). then plug it back in, roll the key back in you car (to give power to the stereo) and see if it works. if not, take it into you local visions electronics and ask them to look at it for you
Dec 11, 2008 | Alpine Car Audio & Video
Alpine CDA-9851 CD Player : Time Display
I turned the clock ON while the radio was on, then when I turned the radio OFF, the clock continued to display. Nice.
Sep 24, 2008 | Alpine CDA-9851 CD Player
Alpine CDA-9825 CD Player Logo
431 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
