Question about LG 30FS1D TV
TV focusing problem
I have a LG CT-34M20ET that has a problem with focusing, blurring picture, I have played with the contrast, and flyback transformer adjustments, no differing in picture, any possible suggestions would be handy.(electronic technician I know TV's can bite) Flames
  • 1 more comment
  • Anonymous Aug 10, 2008
    blurry
  • Anonymous Mar 21, 2014
    multiple image of pictures
  • Anonymous Mar 31, 2014
    Hi, samsung hitron 50cm (CS50F2) refers -On switch-on, the screen is quite bright as if the'brightness' has been turn full. Can see the fly-back line in with. The text (eg when pressing menu) seems to be blurred, out of focus. Attempting to adjust 'bright-control' no effect. I am an electronics technician, was hoping to investigate myself? Any pointers, besides taking it to a repair-shop? Thanks Gert
You will find this is a defective picture tube, costs involved make the repair non viable
Posted on Mar 28, 2007
  • 513 Answers
It's good that you know how TV's can bite, I'll still have to post this in case someone having your problem and reading isn't aware of this and feels lucky- If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. could be a problem with the screen potentiometers block. should be located on the chassis close to where the HT lead passes on its way to the picture tube. Good luck
Posted on Mar 16, 2006
Akai ct 2180 blur picture
change CRT base and reconnect focus wire after cutting away half cm of the wire-end
Mar 21, 2014 | LG 30FS1D TV
Picture blurred
blurred picture can be adjusted,and sometimes replacing of crt socket will solve the problem.
this is tricky so i've advice you to follow what i've said strictly.
Open the back cover of your set (make sure that you unpluged the unit first).
Look for the flyback transformer (it has a sunction cup connected to the picture tube).
You will see an adjustment knob on it, it mark focus but wait before touching,mark it with your pentel pen,marking the original location of the knob is important because that is the factory align.
After marking get an screw driver w rubber insulator as a handle to avoid an electric shock,this will be used to adjust the focus on the flyback knob.
Turn on the unit and hooked it up by your dvd player.
Play the dvd so that you will see a picture on the screen.
Pause it with a picture with characters.
Now you can see the blurred picture?
Try to adjust the focus on the flyback back and forth minimal turn only.
There's a reaction?Yes- continue to get a perfect picture and youre done.
There's a reaction?No- back the knob on its original position.
Your crt socket is faulty.
try some helped of your technician or people knowledgeable of disoldering and soldering technique.
Pull the board on the crt socket.the socket which attached to the tube is the one you are going to replaced. I've adviced you to observe first and familiarized what are going to dis-assemble because you will do the same when you replaced a new one.
After replacing your crt socket,picture ok?Yes-you're done
After replacing your crt socket,picture ok?no-picture tube is faulty.........
Jan 02, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
When i switch dnie jr on i think the picture gets blurred even with maximum sharpness on dvd.
The problem is on The Focus ( FBT=Flyback Transformer) setting, You can adjust it to ge the picture more sharp. or you can replace the Socket of CRT/Flat tube..
Oct 06, 2010 | Televison & Video
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Mar 06, 2010 | Televison & Video
Certain aspect of my sanyo tv are very blurred
This problem requires adjusting the Focus on the flyback . Turn the tv around and look for adjustmen slots on the back. If you can see them, use a nonmetalic small srewdriver and slighty adjust the top or left one. Be careful, it is the high voltage area
Sep 15, 2009 | Sanyo Televison & Video
Picture out of focus at times
Firstly, to get a "Shop" standard picture, you need to have a true HD feed. Usually a demo disc filmed in HD at 1080p, played on a true HD system at 1080p into your TV. Most broadcast feeds at present are on 720p.
However, you can improve the picture significantly just by changing a few settings on the TV:
Contrast: Change to about 65% of maximum. Too much
contrast gives a blurry / grainy image.
Sharpness: Change to about 20% of maximum
Also turn of any dynamic or digital contrast settings on the TV (if it has them)
Apr 19, 2009 | Televison & Video
Non crispy display
Six to seven years is about the usual life of a picture tube, and then you start seeing signs of aging. Poor focus is one common symptom (the loss of crispness you noticed). There is an internal focus adjustment, but it usually can't compensate for the tube. If you want to try it, the control is on a part called the flyback transformer. It's usually found on a rear corner of the circuit board, and has a red wire going to a rubber contact cap on the picture tube. Most flybacks have two little knobs on them, and you want to tweak the one marked "FOCUS" a little to see if improves the picture. BE VERY CAREFUL! WITH THE POWER ON THERE ARE POSSIBLY LETHAL VOLTAGES EXPOSED!
If the focus adjustment doesn't help enough, it's time to look for a sale on an LCD monitor. The prices have come way down, and eBay is a great place to look for deals if you don't want to buy new.
Jan 27, 2009 | LG Flatron 775FT 17" CRT Monitor
Toshiba television is black picture
If this just happens while vcr is playing. Check the vcr. Did you happen to adjust its brightness and contrast settings. If things doesn't change. Then if this model is a crt type could be adjustment on its flyback transformer is needed tweaking slowly its screen knob or tweaking also its focus knob until you got it to the level of viewing it correctly.
But be aware, hazardous voltages inside it. Or let th technician set it for you, its a minor adjustment.
Jan 09, 2009 | Toshiba 36AF41 36" TV
LG 700E monitor gives a blurr vision
open unit, adjust focus pot on flyback, may have 2 focus pots.
do both until satisfied.
If the problem varies with temperature (on time), then you may have a failing flyback.
Oct 02, 2008 | LG Studioworks 700S 17" CRT Monitor
LG tv child lock on how do i unlock it?
my lg tv locked accidentally how can i unlock?
May 20, 2008 | Televison & Video
LG 30FS1D TV Logo
354 people viewed this question
Steve Allison
Steve Allison
