Question about Cuisinart Supreme Grind DBM-8 Electric Burr Grinder
Cuisinart burr grind and brew coffee maker
All of a sudden my cuisinart burr grind and brew coffee maker is not grinding coffee. I have removed all parts, cleaned it and it is still not grinding. It looks as though the coffee is not going into the brew compartment.
  • 7 more comments
  • Anonymous Nov 25, 2008
    The beans are not being ground. It just whirrs without processing the beans.
  • mike92105 Dec 03, 2008
    We are having the same problem. Hear a humming sound but no motor action. I will take it apart this weekend, and let everyone know.
  • Anonymous Dec 07, 2008
    Cleaned coffee maker. Next morning it worked that evening I tried 3 times to make coffee and the grinder makes noise and the water gets hot but when you pour it out there is only hot water with a tinge of brown from the few beans that were ground.
  • embhap Dec 09, 2008
    I have the same problem and I am on my second machine . I took the first back for the same reason.
  • Anonymous Dec 28, 2008
    happened to me too.  resolution?
  • Anonymous Jan 18, 2009
    same problem--called tech and they were no help at all.
    only had this machine a few weeks...
  • Pete Hershman Apr 25, 2013
    Cannot remove grinder from pot to clean after grinding. Grinder sticks.
    Grinding fine. Cannot. Remove grinder to clean
  • Roger Christians Sep 03, 2013
    Mine doesn't do anything. Is there a fuse that's replaceable?
The hopper between the burr grinder and where coffee chutes into the filter is jammed with coffee powder...
First, take out the filter holder and carafe, and place a freash empty filter on the pot base to catch stuff.
Next, take out the beans holder and look for the release lever in the lower left section. Sliding it to the left slides open the door, where you'll probably find loads of powder. You can poke your finger through to get the majority, then use the cleaning brush to get it really clean.
Thanks what fixed mine! (I notice I have to do this about once every few months.)
Posted on Aug 03, 2009
    New Friend:
I had the same problem that the grinder had failed. My machine was about 18 months old so I emailed cuisinart customer services here in the UK (via
They asked a few questions, similar to the ones above above about cleaning the hopper etc, but this did not resolve the problem. So they arranged to have the machine posted back to them (at their cost) and a few days later emailed to say that they weren't able to repair and sent a brand new replacment.
Very impressed with their customer service.
Hope that helps!
Posted on Aug 29, 2013
I found out that if you spray hot water directly into the Burr Ginder and wash it out then do a dry run with no coffee it Will fix the problem.
Posted on May 16, 2010
My cuisinart automatic grind and brewthermal shuts off every minute or so it douse not brew strate through.
• Remove the hopper from the unit
• Lift coffee channel cover
• Clean out coffee chute
• Replace channel cover and hopper
• Your coffeemaker is now ready to brew again
Oct 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Burr Grind & Brew 12-cup, programmable Cuisinart. Even with the vinegar solution, it seems to clog more than we expected. We have a water softener. Tired of making 8 cups and only getting 5...
you must physically remove the lime.
first remove the spray head and then brew the coffee in an empty waste container.
remove all the lime as much as you can.the hot water force the lime to go out .
please rate my work
Sep 05, 2011 | Cuisinart GRIND AND BREW COFFEE MAKER
How do I clean the Cuisinart Automatic Grind and Brew Thermal coffee maker
I clean mine once a month with 6 cups vinegar and a couple cups of water. also replace the charcoal filter regularly.
Jan 14, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
Nov 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I cannot remove the grinder from my cuisinart Grind and Brew Coffeemaker. It still makes great coffee, but I want to clean the grinding mechasim and cannot remove it.
Common with the DGB-600 - you can try icing it down for 10 minutes - once removed, clean exterior with vinegar applied to a rag to get oils off - endemic to this unit - replacing it with exact same model will not help.
Oct 13, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Logo
7,036 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
