Help plz! i cant hear and people cant hear me on ventrilo. i bought this headset+mic brand new, dont know hwy it isnt working.
Try going to Control Panel -> Sounds and Audio Devices Click on Voice Tab and make sure the proper device is selected. Click on Volume and make sure levels are appropriate. Lastly, click on Test Hardware and wait until you can speak into the mic to see the voice levels. If you can see the voice levels, then your mic probably works and it is just an issue of configing the COD settings. goodl luck
Big help. I am not very computer savie, so I was in perill their for a bit. Thanks a lot.
Same problem here... can listen but nobody hears me :-( the help here does not help me...
This thing sux i just bought it and it doesnt even work...i am useing window vista and my laptop is gateway FX and i play WoW and i use the mic for WoW and ventrilo and none of them will pick up me talking
When u have your jabra headset all set up and paird with the ps3 on a game how dow u speak.Do u press the blue light button or what.how do i no they can hear me .and i have the vol on the headset at 5
Thank you very much!
Your headphones might also be muted. If you press both the + and - volume buttons at the same time it mutes the mic.
Hi, can anyone please help me by explaining which settings I need to enable the following?: To be able to speak & hear via the Logitech headset, but also the desktop speakers to work so that I can hear any Skype calls. The headset did work properly but I changed settings, now DT speakers ring, microphone works but can only hear via DS speakers. Please help??? Lambchop
I had a similar problem using my DSP-500. It turned out that the wiring for the microphone had been severed. The folding mechanism that lets you tuck away the microphone into the headset had caught the wire, and eventually cut through most of it. And the wire is not easy to repair. In construction, the wire is very similar to the ones used on the AC adapters for Apple Powerbook G4's that supply Direct Current. Strands of insulated wire are underneath more insulated strands of wire. One set of wires is (+) while the other is (-). It's kind of like the Russian doll of wiring designs. I repaired the wire in my headset, but I'm sure there is a more efficient way of doing it than my method. Good luck.
The microphone is off on your device.
yeah i cant talk either, on the computer or on ps2 when playing online, i can hear, i just cant talk
I try playing Socom and 25toLife and I can hear but no one can hear me! I unplugged the headset from the PS2 and still nothing. What else could I do?
yea
i have the exact same problem, its just that when i talk into the microphone, the people that i am talking to always tell me to turn off my mic because all they hear is static. i relly dont no why this has already happened after 3 months of using it
im playing battle field 2 and everything is fine i go out to the kitchen and come back and no one can hear me but i can hear them, can you help?
I have same problem. When I am on ventrilo my mic suddenly stops working i just bought it yesterday and sound works great, but no microphone. Then sometimes it randomly starts to work again. When i go to sound recorder it records the sound being played out of the headset and not my voice.
i just got mine consumer headset . i play battlefield 2 and i`m having the same problem,i could everyone fine,but they just can`t hear me....pleeeeease someone tell me what to do.
All my friends who have the same headset as me can talk to me, i try and talk but they just can't hear me...how can i get it to work?
i cant talk on my mic but can hear sounds on counter strike source
I can hear fine but the mic doesn't seem to work. I've tried testing and calibrating on both mac and PC, and neither one has fixed it.
Using MSN, I want to know how to program my headset into make voice clips, but nothing seems to work, I've tried configuring my headset in the control pannel, but nothing seems to work.
all connections are in properly. I can here them but they can't hear me.
like the other consumers i have everything connected proper, i can hear but cant seem to use the mic
I just recently bought the Logitech 350 Headset for my laptop. I'm currently running Windows XP (with SP2). My problem is that when I plug in the headset my laptop will recognize that it is there but when I try to speak my voice isn't showing up. I've already tried testing from the control panel but it still doesn't work. Any ideas on what I should do
it is exacly like the thing said cant talk but can hear
i can hear i just cant talk through the mic.
Me to! The solution is not a solution - we all tried this before coming here. I JUST bought this headset, it should work flawlessly
i hear perfectly but my team can't hear me
I would like to know if all of us have defective headsets - have these all been returned to Best Buy?
they can't hear me and im getting pissed off
whenever i try to use ventrilo.com i can only hear but my mic will not work is it a defective mic,jack, or is it just a headset that dosnt work with ventrilo. First i have put everything to direct x sound. Then i select mic. Is the mic not direct x sound is it the other name under direct x sound? Ty for whoever helps.
the headphones work but the mic dont
when i play call of duty 4,i cant talk but i can hear whats going on...and i have gon through two sets of these headsets,one wireless and the second wired.
same here. I tried to talk in Flight Simulator X but no one can hear me. I can hear every1 else though.
Running on a mac. My friend and I bought two of the same kind and the problems with the mics are identical.... just do not work. We bought them to play WoW and there is no support for this issue... Especially on a mac.
When i plug it in to talk with my friends while i play Runescape i can hear my friends but they said they cant hear me and i cant hear myself and everything is plugged in.
can't hear anything
same problem
i try to talk on Ventrilo and on my Speech thing in control panel, neither work
same thing
Same problem. Yes i have run test hardware, it seems to believe there is something there, but it receives no voice output. The headset speakers work great though. Also, the microphone worked for a while, then stopped working randomly one day.
