Question about Acer Aspire 3000 Notebook
Overheating Hi, I have an Acer 3000, have had it looked at by a technician, he tells me it was shutting down after short periods of time due to overheating. On further inspection, he informs me the cooling fan thing has corroded and needs a new one. My question is, do you know where I may be able to source a used/second-hand one from, preferably without having to look overseas. Or, are you able to hook me up with one, I would be extremely grateful. Unfortunately this, (was bought in used condition) is the second Acer laptop I've had thats broken down on me and I would like to get this one up and running rather than throw it away like the previous one. PLEASE HELP.
  • nessie72 Sep 10, 2008
    Hi, Im in New Zealand.
    Brigadier General:
  • 5,158 Answers
What country are you in ?
Robert
Posted on Sep 10, 2008
  • Roberta Smith
    Roberta Smith Sep 10, 2008
    ok ... did you spill something on it or happen to live close to the sea ?
    Robert
  • Roberta Smith
    if the fan does not work entirely that is one issue and i'll do my best to locate a source for a fan for you.... but if it needs to be cleaned and the dust removed you won't need to buy a fan....
    Robert
Acer aspire 3000/5000 I tried several things and still it starts to power up and can hear it running for afew seconds then it stops screen stays black and power stays on the battery is fully charged
Do you see any error messages? Does it lose all power when it shuts down?
It could be an overheating issue. I suggest you get it checked by a technician.
David
Jun 10, 2013 | Computers & Internet
My acer aspire 3000 turns off suddenly when am watching videos and also when am installing office.
Turn off( shut down or restart automatically)?
It maybe cause from overheating from your graphic memory device/harddware or problem with your processor.
Are you have using fan or anyelse to cooldown your laptop during you using it?
Try something, using any fan that can cold and maintain temperature for your laptop to avoid it from overheating. Overheating is not good. It will cause your motherboard problem or screen monitor problem.
May 24, 2011 | Acer Aspire 3000 Notebook
My Sony Trinitron stand by/timer light is on and will let me put tv on but only stays on for a few seconds . Model #KV27S66 Oct 99
Your TV has an overload due to some faulty components inside it. This type of fault is usually noted with overheating of horizontal output transistor connected to LOT of the TV. This may be due to LOT fault, or fault to the transistor itself. When it overheats, it put a short between supply rail, and the power supply regulator system inside your TV will detect that short and will shut down automaticaly. Please note; if the TV works after some time, say after 15 or 20 minutes; and again shuts down after working for a short period, and the cycle repeats, surely there is a winding short inside LOT, which cannot be detected by normal multimeter measurments. If it is so, replace LOT and the horizontal output transistor at the same time.
Oct 14, 2010 | Sony Televison & Video
SHUTS DOWN AFTER A SHORT PERIOD OF TIME. GREEN
this is a technical problem.have someone professional come and take a look.
Jun 15, 2010 | Heating & Cooling
Acer aspire overheating & rstarting.
you can replace the fan if you know how to do so but take it to a qualified technician and they will be able to sort it out for you and it should be that expensive
May 29, 2010 | Acer Aspire 5100 Notebook
Should I bother trying to fix this laptop or is it time for new?
it would be cheaper to get a net book and an external hard drive you can get a good one for about 200$ and an external drive enclosure for like 20 and a used hard drive for like 30-40
Dec 17, 2009 | Acer Aspire 3000 Notebook
Left side of my lenovo 3000 n200 overheating
Usually left side of the laptop is where the cpu and air bent is located. If this is overheating, try to elevate the unit to free it to get air, or clean the airways bent. If you are still get overheating clean the unit by getting into the fan or check the fan.
Jun 04, 2009 | IBM Lenovo 3000 N200 PC Desktop
Acer Aspire 3000 notebook constantly overheating and shutting off
purchase what they call a chill pad... it plugs into a usb port on the laptop and has two fans... you set the laptop on top of it....
Robert
Jan 05, 2009 | Acer Aspire 3000 Notebook
Overheating issue - looking for service manual
I had the same problem. And i believe my method has the fix.
On the bottom side of the laptop, unscrew the door to access the CPU Fan....(closest to the power supply)
Make sure the system is OFF and not plugged in or no battery in.
You will see 2 tabs on the copper heat sync that holds it down to the cpu.
Unscrew both the visible tabs.
Bend Both Tabs upward to where when you screw it back down there will be resistance.
What that will do is secure the heatsync to the die of the CPU.
replace the CPU door, and start her up.
Hope this helps ya'll
Nov 26, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
