Question about Whirlpool LER5636P Electric Dryer
Hotpoint tumble dryer
Hi there my dryer doesnt heat up please could you tell me if it is the heating element a i looked at it and the coils seem fine its the piece that runs through the middle as spilt is this the problem or could it be the thermostat. please help
  • 958 Answers
Hello ginger, it would be best if you know how to test the parts for continuity
you can use an ohmeter to test the continuity.
i could guide you step by step.
and please look at the schematic inside the control panel . remove the back cover and usually there is a folded paper there.
tnx 4 using fixya,
drcool
Posted on Sep 09, 2008
Hotpoint dryer model #dlb3400sblwh not heating up
hi u can check see if heater looks good if so more than likley themostat gone just above heater element
Feb 13, 2013 | Hotpoint Dryers
No heat
Well first of all you can tell us the model number of your dryer, so we can help you...... anyway if your dryer is a electrical dryer then first you check Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please post comments for further help or information..........
Good Luck!!
Mar 28, 2010 | Hotpoint Dryers
Hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Dec 20, 2009 | Hotpoint Dryers
Dryer wont heat up on a aquarius VTD00, do you think its the element
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. . Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. Also overloading and blocked filters can lead to thermo cut out, it is best to check your manual and call someone out on this occasion. You may even have a red reset button on the rear of your machine some models do, if yours doesnt then call out engineer :)
Jul 19, 2009 | Hotpoint NWXR473EV Dryer
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint tumble dryer tdl31p
If you are getting 240v on all element connections then you are missing a neutral and the element will not heat.
Please check this and post your findings.
Thankyou.
Jan 23, 2009 | Dryers
I have no heat from my hotpoint aquariur ctd20 tumble dryer
The element and stats are located behind removable panel at rear of m/c.
To test , you will need a multi meter set on the ohms range for continuity check., and you need to pull the wires of the components to get a proper reading.
THE M/C MUST BE UNPLUGGED prior to this check.
Check and clean all filters, remove the front bottom left filter, and clean by running under cold water.
Hope this helps.
Plz rate my solution
Thanks.
Dec 28, 2008 | Hotpoint Aquarius WD63 Front Load...
How to fix Hotpoint CTD00 Tumble Dryer?
http://www.fixya.com/support/t232066-hotpoint_ctd00_trips_power
The link above should solve your problem. I have the same problem and my parents who bought the same tumble dryer also had the same problem. Its water backing up to the fan then its hitting the heating element which is tripping the electric off.
At the back of the Tumble dryer near the bottom you'll see a panel that has about 8 screws that you can taqke off as well as a small panel that cover the pivet for the drum. If you unscrew this you will see the fan and heating element and no doubt a small puddle of water and damp dust that has clung onto the panel. You should dry this with kitchen roll and clean the old dust off then carefully turn the tumble dryer on (at your own risk lol) or you can take the advice of the person who posted the link above and use a hair dryer. This will stop the element getting wet and tripping off.
Also there is a water reservoir to the right of the panel i mentioned. If you prise the clips open and remove the top section you will see the water in the reservoir. If you look inside it on the bottom left hand side there is a little **** that the water drains in from. If you use something like pipe cleaners or a knife and wiggle it about you may have some fluff or hair trapped there that is making the water back up to the fan and causing the tumble dryer to trip off.
Hopefully this willsolve your problem for the time being but the filter in the bottom of the dryer needs to be cleaned thoroughly every week or so to stop this happening again.
Personally i think this is a major design flaw and the tumble dryer should be recalled but Hotpoints aftercare service is awful to say the least so lesson learnt, don't buy a hotpoint tumble dryer!
Feb 01, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
