Question about Bosch Washing Machines
With only 1 item in Drum my new Bosch WAE24363 will not perform a spin cycle, yet adding more item into the drum then the machine will perform a full spin cycle. Why will the machine only do a full spin with more items added
    President:
  • 1,462 Answers
Most modern machines have an out of balance detector to prevent the machine being damaged with a badly balanced load.
with a single item in drum, load will not balance and out of balance detector comes into action and prevents spin
Posted on Sep 09, 2008
Severe vibration/noise during spin cycle. What could the problem be and how do I fix it?
if the machine was run severely out of balance (rugs) you'll need to get a look in the back up near the top with a good flashlight , this involves unhooking power and hoses and turning it around , you may have broken a drum suspension link , this device (three) keeps the drum from contacting the shell , if its true and its allowed to run this way you will brake off water hoses on bottom of drum and water will runout on floor
Feb 09, 2016 | Bosch Washing Machines
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Kenmore front load washer won't spin
May be the enginer have gone bad ,you can check if there is something wrong .
Feb 25, 2013 | Washing Machines
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
The washer won't spin. I have one light blanket in the machine and it won't spin. I turned the machine to a regular wash cycle to see if the drum would spin and it did. When I turn in back to the spin...
Hello, Welcome to FixYa. What I'm going to tell you can be validated with the Bosch owners manual so I suggest you check into it. The reason the Bosch will not spin with just a single item (regardless of weight) is it isn't designed not to. If you add a similar garment of equal or similar mass it will spin. These units rely on weight differential to determine balance...if one side of the basket has too great a difference from the other, the dyno on the motor will not allow it to spin. Thank you for choosing FixYa today and good luck. Please let me know how it goes or if I can assist you in any manner going forward. Regards, Macmarkus :)
Apr 05, 2011 | Washing Machines
Overload affected performance. Even when only got 1 item in machine. Makes lots noise when spinning and inner large plastic seal looks like something caught on it and shredded some of plastic.
this fault can be caused by the drum halves becoming tight .they move together due to limescale deposits between the drum spiders. the noise is most likely a failing drum bearing
if the plastic seal is damaged then it will need a new drum assembly
they are no longer available from dyson due to supply problems
you may be able to get another machine from ebay and fix yours using parts from each machine to make one good one
Nov 10, 2010 | Dyson CRO1 Front Load Washer
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
321 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
