Samsung laptop installing lexmark printer inputting code it shut down won't restart (nothing)
Control panel
unplug printer from power must be unplugged
delete lexmark software if installed ( you can uninstall program from control panel )
go to lexmark website and download software for your computer
shut down computer
plug in printer
turn on computer
wait for computer to completely boot up then turn on printer
Feb 15, 2014 | Samsung Computers & Internet
I've just formatted my C drive, and installed everything but struggleing to install my Lexmark X2500 printer. It has the USB connection but windows won't automatically install it for me. Ive tried...
Try downloading theprinter driver from the Lexmark WEB site.
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-
Aug 15, 2011 | Lexmark X2500 All-In-One Printer
I have installed the latest download for my Lexmark 715 printer on my new computer. It says the printer is installed and ready to print. However, when I try to print my computer does not communicate with...
Make sure that in control panel/printers. Yours is set as default.
Next try shuting down pc,disconnecting printer,then restart pc and reconnect printer.
Nov 30, 2010 | Lexmark Z715 InkJet Printer
Preparing for Scanning Application box
dear uninstall your printer driver .......
shut down your system and disconnect printer .....
open system and install driver ......
after installation connect printer
and enjoy it ..................
Nov 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
Computer says it is busy when I try and print out a page, just installed new black ink cartridge and it won't try and print anything now.
1. Check to make sure the black ink cartridge is installed properly.
2. Check to be sure no printer alignment program is trying to run.
3. Right click the printer icon on the tool bar and see if any print jobs are still lingering. Cancel them or Restart them. Printer should pickup and start working from there.
Last resort:
4. Shut down the computer and unplug the printer for at least 1-2 min.
Restart everything paying close attention to any error messages.
If none, the printer should work again provided nothing serious has happened.
Hope this helps!
Oct 17, 2009 | Lexmark X2600 InkJet Printer
Setup to lexmark x4650 wrong
Deleting it from the desktop, just deleted the shortcut key is all. It'll be alright. Just ease back, and let's fix this problem.
Click on Start>Hover your mouse cursor on All Programs. Look to the right for Lexmark. In the drop down menu under Lexmark, look for -> uninstall.
Click on it. This is the best way to uninstall a program. If it asks if you want to save any personal settings, -> No!
No uninstall option? Okay, click on Start>Control Panel>Add/Remove Programs.
When Add/Remove Programs has populated, scroll down through, and find the Lexmark software. Click on it. Now go to the right, and click on ->Remove.
There may be more than one, Lexmark software listed. If so, you have to Remove each one.
This is why, after you remove one part of the Lexmark software, (If there is more than one part),
AND you're asked if you want to restart your computer, the answer is NO.
You click on Restart Later.
This action will bring you back to Add/Remove Programs, where you can continue removing all Lexmark software listed.
Keep clicking on Restart Later, until all software is removed, and you are back at Add/Remove Programs. Then close Add/Remove Programs.
Close all windows until you are back to your desktop screen.
Unplug the USB cable from your Lexmark printer to your computer. Turn the Lexmark printer off, if it is on. Unplug the printer from power.
You are unplugging the printer to clear error codes, in case it stored any.
Shut your computer down normally. Turn it off.
Unplug it from power. Press the Power On button in, and hold it in. Hold it in for a count of Five seconds.
(And I mean Five at least. Count, 1001,..1002,..1003,..1004,..1005)
Let go of the Power On button. Do this same procedure Two more times.
What you are doing, is clearing any error codes in the computer. This may be a bit much, but I suggest you do it. This way there is no room for error.
Plug the computer back into power. WAIT 1 minute, then turn it on. When Windows has fully loaded up, install the Lexmark CD.
Follow the instructions. If it asks you to restart your computer, Okay.
After Windows has reloaded, click on Start. You should see a small pop-up stating you have a new program.
Now, plug the Lexmark printer into the computer with it's USB cable. Plug the printer into power.
WAIT 1 minute. The printer may have to reset itself. Now press the Power On button of the printer.
You should be good to go.
Apr 28, 2009 | Lexmark X4650 InkJet Printer
My computer recognises the printer is there, but nothing prints
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Nov 24, 2008 | Lexmark International Z615;...
Printer problem
Remove your printer from the available printers by deleting it. Shut down. Restart and reinstall it. Make sure your cables are connected at the time the manufacturer tells you to.
Dec 21, 2007 | Lexmark X4270 All-In-One InkJet Printer
Laxmart x73
Insert your Lexmark Xx3 Installation CD (disc 1) in your CD-ROM drive. Make sure your computer is on. Once you see the Lexmark Installation screen, click the Install Now button. Wait while files are loaded onto your computer. Click the Next button. Click the Next on the directory window. Click Next on the following screen. If your USB cable is connected to your Lexmark All-In-One product, disconnect it now. Click OK. Wait while the software is installed on your computer. When the next screen appears, connect the USB cable and click OK. The printer should now be installed and ready to use. Already installed the software but it appears the printer driver is not installed To verify the printer driver is not installed follow these steps: Attach the USB and power cable attached to your device Restart your PC Click Start. Click Control Panel. Click Printers and other Hardware if the icon exists. Click Printers and Faxes If your printer does not appear in the list then please follow the remaining instructions below. Unplug the USB cable and power cord from the back of the printer Insert the Lexmark Xx3 CD into your CDROM drive if it is not installed already. If the CD automatically runs, click Cancel. Click Start and select Run. In the Open box, type the letter of your CDROM drive followed by prtsetup.exe. For example: D:\prtsetup.exe and click OK. A Lexmark License Agreement will appear, click Accept. A progress bar with the percentage of files copied will be displayed. Next a communication error will appear, click Cancel on this message. A printer registration screen will appear, click cancel or exit. Click Start and choose Shut Down. In the Shut Down window select Restart. While the computer is restarting reconnect the USB and power cables and power the printer on. Once the computer has restarted Windows should detect the printer. if still it is not working try with another usb cable
Sep 12, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
