HP CUE Status has stopped working error message
  • 3 more comments
  • dennyh Oct 07, 2008
    I have HP officejet pro L7580 using Vista Ultimate also have Roxio 10 Please advise when fix available dennyh@sc.rr.com
  • Deadman43 Oct 19, 2008
    I also have the same problem. I do not have Roxio although I did and took it off and installed nero I have an HPD5069. I have reinstalled the printer drivers and I still have the issue. Have seen alot of this out there, but have not yet seen and end to it. Hope to solve soon, will post if I do.
  • Anonymous Nov 02, 2008
    No matter what I try I can't get rid of it.
  • juniornet Apr 02, 2009
    I've installed the full HP PSC 1510 software on windows vista 64 and I've got the same problem. Deactivating the service on Start->Services doesn't work for me.
  • Anonymous Apr 17, 2009
    Using printer HP C4180 all in one.
    Installed Roxio creator 2009 taking a lot of time with no result. I can not find creator on my PC.
    Get the same every reboot: HP cue status has stopped
    Thank you
    Ruben Denmark
3 Suggested Answers
  • 26 Answers
SOURCE: Continuous error message
delete the hp cue discovery on your add/remove programs
Posted on Jul 18, 2008
  • 86 Answers
SOURCE: hp cue status root has stopped working
click on the start button go to start search bar and type services.msc and hit enter now a window will open look for hp cue in that and check status it should be started and automatic not mannual or automatic delayed if its started then there is a problem with the cue version of the hp software
now try downloading the driver through the link and reinstall the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3311800&lc=en&cc=us&dlc=en〈=en&cc=us
Posted on Jul 10, 2009
Hp cue status root has stopped working
Jul 10, 2009 | HP Deskjet D1455 InkJet Printer
Hp CUE Status Root has stopped working ERROR
You should try using Windows Restore. Restore the computer back to when it worked correctly. Then try downloading the latest software for your scanner, etc. from the appropriate websites. i.e. support.hp.com
etc...
That's probably the easiest way to do it.
Feb 20, 2009 | HP Pavilion dv9700t Notebook PC
i had this prob. the "hp cue root " error isnt a hp thing, its a microsoft thing. i beleive it was caused by installing a older model printer AFTER installing a newer model. (i had a hp 2500 series,then installed drivers for a hp 1400 series)
just go to control panel, then "programs and features" , then uninstall everything that is assoiated with the printer your no longer using. just deleating the older printer from the "printers" folder won't do it. (this is assuming that you dont need both printers)
I havent gotten the error message since i did this. besides, its a good rule of thumb to not have drivers that you dont need on your machine anyways.
hope it helps
mkyckrv1
Feb 07, 2009 | HP Pavilion dv6000z Notebook
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
I need hp cue status patch plz
please i have vista and a message hp cue status
Dec 01, 2008 | Office Equipment & Supplies
HP CUE Status Root Error
It appears to be a problem with HP Cue Device Discovery Service, the tray notification that tells you when your ink is low, etc.  I solved it on a Vista machine by taking Cue out of the Startup tab in msconfig.  (Could show up as HP Cue Device Discovery Service, or  hpqtray08.exe.)  Note that this will also disable the tray icon and its automatic notifications.  All it does is take Cue out of the startup list, but we don't see the error any more and it hasn't affected the printer's functions.
HP has further advice on deeper "cleaning" for the error: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpy20854
I haven't come across anything other than manual methods of getting rid of the error.  No updates or patches that I've found.
Aug 15, 2008 | Office Equipment & Supplies
Jul 17, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP printer 6540
try restarting the spooler
goto start - run - then type "Services.Msc" without the quotations obviously, the look for Printer Spooler - right click on the line, and left click stop.
once it has stopped its status will change from running to stopped, then right click and left click start.
this should hopefully clear any jobs it thinks it has in the queue.
Jan 17, 2008 | HP DeskJet 6540 InkJet Printer
952 people viewed this question
jasbo
jasbo
