Question about LG 42PX5D 42 in. Plasma HDTV
Green line my 60' lg plasma is only 3 weeks old and has suddenly got a 7' single dot line running vertically domn just off from the cenre
  • Anonymous Oct 07, 2008
    Got the same problem, brand new 60"PG7 Model TV. 8" vertical green line on the right hand side of screen.
    LG and supplier think it is the others problem
    Australia
  • moranbah Oct 07, 2008
    Got the same problem with a 60"LG PG7 TV
    Brand new and the dealer and LG both think its the others problem
    8" Green Line on the right hand side of screen
    Andy
    Australia
  • 4,234 Answers
With a set this new, don't waste any time on it. Return it for an exchange. Do not accept a repair. You should not have to wait for a repair. Request an exchange. Basically there is either a bad connection to the panel or a defective panel.
Dan
Posted on Sep 09, 2008
Lg 60Pk750 plasma green lines
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 10, 2016 | LG 60PK750 60 in HDTVReady Plasma TV
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Green line plasma
Sounds like a COF fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 15, 2014 | Televison & Video
60inch lg plasma green line down the middle
Visit this site named 'Electro-help' These type of fault to plasma TVs are described in detail there. Almost all plasma TVs will have same structured circuits. You can find which board to your TV is faulty, by referring details from this site. Check this link, and select the site named above. Pull up older posts there.
Jul 30, 2012 | LG 60PS60 60 in. Plasma HDTV
It is going to be one of two basic issues:
1. There is a poor connection somewhere in the set--either with a plug or cable or on one of the boards.
2. There is a board that is beginning to fail causing this.
Either would require a shop and may or may not be worth the cause.
Having seen hundreds of these sets all are more prone to flaky problems than the older sets and average life span is 3-5 years.
Shop I work for 80% of them are 2 years old or less.
If problem began shortly after set was moved or relocated I would lean towards a bad connection somewhere.
Mar 17, 2012 | LG 50PK550 50 HDTV Plasma TV
I have a 6 mo old lg 60 inch plasma tv. 2- 1" greyish vertical lines running down just off left of center.
start hunting down your warrenty info before you do anything. If you try to repair own your own you will void it at this point
Mar 24, 2011 | LG 60PC1D 60 in. Plasma Television
Green screen on Lg 50" plasma TV, you can hear the channel but it is a full green screen
I am having the exact same problem with my LG 50". It's two weeks old. Has anyone found a solution?
Oct 28, 2009 | LG 50PX5D 50 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
48 people viewed this question
Computer Repairing
Computer Repairing
