Question about Honeywell Programmable Thermostat Heater
Honey well thermostat
We have moved into an older rural home and the heating system is run through a honeywell thermostat. The heating unit itself is a huge one out side and the back of the house and vents the heat through the floor. We are not sure how to use this system and have been left no instruction. The house is huge so its stays very cold in this weather without heating working correctly. I turned on the system out side and the thermostat came on but I am not sure what setting to put it on. Can you help?
The thermostat box is rectangular and has a digital clock top left and eight buttons to the right. Letter A through to D on the bottom line then an up down arrow followed by a minus sign and a plus sign then last of all a tempreture button that tells you the room temp.
Kind Regards
Sarah Ponder
  • vicki987 Apr 06, 2009
    Hi we seem to have the same system as the previous person and are not sure how to use it Do you have an instrucyion book??
    Thanks Vicki
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Call a reputable serviceman to change the thermostat and tell you about your system, and if you can have it repaced "free" before the clause kicks in!(down here ,we have from 10-14 days to find out if something is wrong for the realator to repair--or replace or adjust the total home sale.. (oklahoma )!
Posted on Sep 09, 2008
Older pictures of honey wells
Paula, remove the cover of the thermostat and look for a model number. The actual thermostat may have to be removed from the sub-base to find it. There may be either a long line of pins on the sub base that matches up with holes on the back of the thermostat when you re attach it....or there may simply be a 3" long ribbon connector that makes the connection.
Once you have the correct model number call Honeywell Customer Service at 1 877 841 2840 and work your way through the menu until you get to 'if you a homeowner push this number'. Once in touch with a live troubleshooter, they should be able to assist you in programming. You should know what kind of system you have, gas, electric or heat pump heat with central air.
You MUST have the correct model number BEFORE you call.
Nov 10, 2015 | Honeywell Programmable Thermostat Heater
I have an older square mercury Honeywell thermostat in my apartment. Furnace works fine in the main house using same model Honeywell thermostat. There is no heat coming from the apartment baseboards. I...
should have 24 volts @ t-stat. if tis is a boiler system it could have air in the zone that stays cold. bleed the radiator out and this should get the heat into the area you want.
Dec 06, 2009 | Honeywell Programmable Thermostat Heater
Honey friedrich replaced with a honeywell RCT 8100
on some of the older models you must go into the installers program to make sure it is set for heating and cooling. also possibly gas or electric heat. and fan on during call for electric heat. these are all sellections in the installers program and usually they have one or more options for each sellection. see the installers guide for your tstat.
Nov 23, 2009 | Honeywell Electronic Programmable...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Have moved into a house which has a honeywell CM5000 heating system but dispite resetting the time date and temperature in each room it still won't start.Have had the airconditioner on during the summer...
dont know the square footage of your home or how many units you have. unless you are in and out of your home for long periods of time and need a digital thermostate. get rid of it. install a 30 dollar honeywell or call a prof. to f@##$%^you.
Apr 25, 2009 | Honeywell Electronic Programmable...
BOUGHT AND REPLACED A HONEYWELL ROUND THERMOSTAT AND THE HEAT WILL GO ON BUT WILL NOT SHUT ITSELF OFF WHEN THE TEMPERATURE GETS TO THERE. IT KEEPS RUNNING TILL I SHUT THE THERMOSTAT OFF. I FOLLOWED THE...
look at the old thermostat and in the middle of it theres a arrow that is pointing at numbers that is called a heat anticipator. then on the new thermostat make sure that its set the same.
Feb 21, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
My boiler keeps firing up even when the Honey well programmer is in the off position. The programmer is about 7 years old.Do I need a new one, a new battery for it or is it to do with the boiler (oil)...
I had the same problem. I traced it to the micro switch in the water/central heating motorised valve having shorted out.
I replaced the (Honeywell) motorised valve and it is now only running when it should.
Jo
May 01, 2008 | Honeywell Electronic Programmable...
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
130 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
