Question about JVC GR-DF450 Mini DV Digital Camcorder
No image through view finder or lcd monitor
When I turn the camera on I get a message "lens cap" The lens cap is not on the camera, the message goes away and I get no image through the view finder or on the lcd monitor. I can still view video previously shot and menus etc.
  • 8 more comments
  • Soundstream1 Nov 11, 2007
    I have the exact same model and problem. Unfortunately its past oct 07. Any suggeations on where to take the camcorder to get repaired? heard how much this might cost?
  • Anonymous Nov 22, 2007
    No image through view finder.
  • flipflop73 Dec 14, 2007
    Yep, just tried to use my camera after several month. Play back is fine but cannot get an imagthrough viewfinder or lcd monitor. Says lens caps, even though it is not attached. Anyone found out anything?
  • Dreww Dec 30, 2007
    My camera needs full daylight in order to work or it shows LENS CAP when switching on. It will record in full daylight, however it has lost the ability to handle different light levels, it seems fixed on normal daylight. It plays back no problem.
  • mclh3853 Dec 30, 2007
    Same problem have contacted JVC!!
  • Anonymous Feb 27, 2008
    I have had the same problem. It just says "lens cap" and i dont even have a lens cap on there? I think i might send it into JVC. Has anyone done that? Does it cost a lot?
  • Anonymous Apr 02, 2008
    I've been using this camcorder 3 yrs. Then, suddenly, LENS CAP problem happened. Does anyone know how much the repair cost ?
  • soekimin Jun 26, 2008
    I've opened the camcorder ,and have found out that the lens is not funtioning . I have change the lens with one that works an so it works,but my problem is that I could not find the specific partnumber of this part can you help me with the number of the parts and where Can I order it I'm from Suriname
  • Anonymous Aug 11, 2008
    no image when i turn on the camcorder all other parts seem o/k
  • melendezpa Oct 12, 2008
    I have hit the reset button on my GZ-MG27U and nothing happened. I still get the [lens cap] and a black screen on the view finder and the lcd screen. Lets all protest!!!!
  • 513 Answers
JVC has acknowledged a fault on their side that will cause certain models to display the "lens cap" error, and they offer free repairs, unfortunately your model isn't on the list. You still might get some consideration, since there are plenty of models from the GR-D series listed. Here's a link to the JVC site : http://www.jvc.com/support/notification/index.jsp?pageID=2 You're not alone though, it's a very common problem also with models that are not listed by JVC. I only heard of complaints by people that JVC refused to help, but it won't hurt trying, maybe they'll give in to public pressure eventually. Good luck
Posted on Mar 14, 2006
I had same problam with jvc gz-mc 500 with lense cap error on screen, even if you open lens cap at scree it says lens cap. no picture, blank screen. although rest of all parts works correctly. i found solution here thanks. i hit with my finger almost 1 inch behind lens, at first it shows grey picture not color, i continue hitting close to lens , slowly slowy it started to appear colorful picture and now it works. thanks for the solution. great solution at no. 1. keep struggling until you find the solution. it makes feel good.
Posted on Sep 19, 2009
I had a similar problem and someone recommended the following solution (which sounds a little odd, but it worked). Use a hard object (screwdriver, key, etc) and lightly tap the top of the camcorder just behind the lens. It worked on my device.
Posted on Nov 01, 2007
Had the same problem with my JVC GR-X5. After contacting repair centers with no joy I decided as a last resort to tap firmly with a screwdriver and hey presto it worked. Thanks for the post!
Posted on Nov 28, 2009
I had the same problem with my JVC Everio GZ-MG21
the tapping about an inch behind the lens with a screwdriver worked! Thanks for the tip.
Posted on Mar 23, 2008
    New Friend:
I have the model JVC GZ-MG27U. It aslo gave me the lens cap error. When I called "Customer Service" (Yeah,,they serviced me,, only I had to bend over to get it). They asked me if the IRIS was open. After Looking into the lens with a bright flashlight I could seea small Triangle. The Iris was stuck in the middle while opening. Which is why when you nag it with a screw driver it fixes it. JVC Recommended I contact a Repair Center. I recommended they contact a Proctologist. I am going to get my hammer now and try the fix. Good Luck!!
Posted on Nov 05, 2014
I saw a solution to this problem posted in another thread, as I was having the same problem with JVC GZ-MG40. Try tapping the top of the camcorder, about 1 inch back from the lens with the tip of a screwdriver or something else hard (key, coin, etc). It worked for me. Now I just have to wait and see how long the solution holds for.
JVC will repair this issue for free until Oct. 1st, 2007. CCD Program for This Model - GR-SXM755US JVC has received reports that in certain circumstances, this model may, while in the camera mode, show no picture, a distorted picture and/or display ?LENS CAP? even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Until October 1, 2007, repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at JVC Factory Service Centers. Please call our Customer Care Center at (800) 858-6442 if you encounter any problems in obtaining a free repair. We apologize for any inconvenience and are appreciative of your understanding and support.
Posted on Sep 11, 2007
I got the same problem with my jvc mini dv. No picture on screen & sign saying 'lenscap' when the lenscap is off. Only used it 6 times ! It appears jvc have no interest in 'customer satisfaction' or 'quality control' when they clearly know about this 'common problem' and refuse to rectify it. I hope the general public wake-up to the fact they are being 'ripped-off' by jvc and refuse to buy the brand. thereby jvc will go bust and won't be able to rip-off anyone else.
Posted on May 08, 2007
Same problem I've got and some repairing shops asking from 200 $ up to 300$ without any warranty.JVC support does not want to understand the problem. So, I'd recommend to those buyer who wants to buy JVC to change their choice.
Posted on May 07, 2007
2 Suggested Answers
  • 13433 Answers
SOURCE: no image through view finder or lcd monitor
try removeing the battery and then trying again,
The device might need a reset
but it sounds like a hardware side problem witch would need to get repaired.
if you still have warranty then that should save you.
if you dont have warranty id recommend you contact your dealer, or a local professional, there is a repair service finder in the front page of fixya under the top experts.
If you need more assistance let me know, I'm here to help
Posted on Apr 12, 2008
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
Apr 12, 2008 | JVC GR-DVM96U Camcorder
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
D80 Monitor does not function as view finder.
To be able to do what you want, your camera would have to have a feature called "live view"....yours does not.
Jul 21, 2010 | Nikon D80 Digital Camera with 18-135mm...
LCD on - view image prior to taking photo
The feature you are referring to is called "Live View mode".
This is NOT available on the Nikon D80, and was only introduced on the D90, which is available now.
Live View mode allows you to use the LCD screen as your view finder instead of using the eyepiece, but unfortunately, this feature is not available in your model.
Jan 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
No picture on lcd & view finder
PLease see http://www.fixya.com/support/t131881-sony_cam_recorder_wont_record for more information on this i have had the same problem, faulty CCD image processor chip.
Apr 01, 2008 | Video Cameras
No video
In camera mode if you look through the lens and have a black picture with the message lens cap on and you see that the iris is opening up and there are no bad connections to the ccd then the imager is suspect. Your snowy playback picture problem may just require a clearing however.
Feb 17, 2008 | JVC GR-SXM260U Camcorder
Canon S1 IS view finder / LCD monitor black out
This is a defective CCD that Canon is repairing free of charge. Go here for details: http://www.usa.canon.com:80/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8044&keycode=2112&id=29819
Nov 24, 2006 | Canon PowerShot S1 IS Digital Camera
JVC GR-DF450 Mini DV Digital Camcorder Logo
1,214 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
