Question about Zanussi Washing Machines
Zanussi Dishwasher ZDI 6063. Programme switch is faulty I think. Set the programme on A, B, C, D or E and it doesn't respond only makes a 'clicking' noise and goes from wash to dry in seconds with the programme light & End light flashing, but nothing happpens but a clicking noice. I think it may be programme timer - but don't know where to get one. There are two numbers on the panel 1) Bitron Code 30410471 and 2) Electruxcode 111147014. 230v/50H T65. Is it fixable? Thanks Ronan Greene
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Posted on May 23, 2008
SOURCE: Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Posted on Apr 02, 2009
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Posted on Jun 02, 2009
SOURCE: how to disable the alarm on a Zanussi ZWD16270W1 washing machine
To deactivate the audio alarm that denotes the end of the cycle signal carry out the following procedure:
press the left two buttons in the row of three buttons on the front panel for six seconds, carry out the procedure again to reactivate the audio alarm.
(The two buttons are labelled as SPIN and OPTIONS respectively)
Posted on Jun 27, 2009
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
Aug 29, 2016 | Zanussi Dishwashers
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Jun 26, 2016 | Zanussi Dishwashers
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi washing machine error code e80
An error has occurred with reading the programme selector control. This can be resolved simply by turning it to "0" and selecting a programme again. If this doesn't cure the problem you may need to seek professional help.
Nov 19, 2011 | Zanussi ZWF1430W Front Load Washer
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Bosch builtin 60cm SGV4313 dishwasher
many thanks however intend purchasing new machine
Sep 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Zanussi FLE1416W Front Loader
Most possible reasons that the door switch or timer unit is defective. The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. if you think that a user manual may help you more, it can be downloaded ($8.95) at url:
Jan 22, 2008 | Zanussi FLE1416W Front Load Washer
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Washing Machines Logo
106 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
