Question about Avanti FF1101W Top Freezer Refrigerator
GE Hotpoint HTS17GBSERWW
This refrigerator is noisy all the time and it trips the electricity. Can anything be done to correct the problem. The unit is about 2 years old.
I has a similar problem with mine (4 years old, noisy, tripped the breaker, but also not cooling properly) and the cooling fan blade had separated from the fan motor. You can SEE the fan at the back of the freezer behind the slotted panel. If that's the problem, it's easier to relace the fan than it is to change the toilet paper roll. Empty the freezer, unsnap the plastic cover, unplug the fan motor, unscrew it, and replace. Just turn off the fridge first.
Posted on May 27, 2013
Tripping a circuit breaker (by any device) is an issue that is not easily (safely) addressed on-line. Besides an actual problem with the device in question, one must consider: a) Too many high current devices already on the circuit (toasters, microwaves, washing machines, etc.) that contribute/cause the issue. b) A circuit breaker that trips much more easily than it should (from tripping too much - common problem), and should be replaced.
c) The device in question needs the compressor replaced (very rare in a two-year old device), but can become damaged during shipment - on it's side. d) Damaged sub-component (eg. one of the fans), probably easily found by locating the source of the noise.
Posted on Dec 27, 2009
My hotpoint rfa52 just started to trip the electric out no warning just kept tripping it out
drawing excess current due to either a short in wiring,, or could be bad fan motor or compressor windings
Aug 28, 2014 | Refrigerators
Electric Hotpoint range - has a intermintant beep 24/7 & oven will not stay on
You will need toreplace the control board on that unit. GE owns Hotpoint and all parts will come from GE the part states (gas) but it is the correct part for your unit. Here is the part to order.
Nov 24, 2012 | Hotpoint RB757 Electric Kitchen Range
I opened my freezer (arctica) and heard a sizzling sound -- i could see coils behind the grates on the back wall of the freezer that were bright red (like an electric stove coil on high) -- the water was...
I hope you unplugged your unit or tripped the breaker. If they are bright red then you have an electrical short that should have tripped the breaker a long time before they turned red hot.
Jul 15, 2011 | GE Profile Arctica Stainless Steel Top...
The motor is constantly running and so so noisy and the outsides of the freezer get extremely hot
Unit is low on gas. You may be able to have it regassed but it will probably need to be done again at some time in the future as there must be a leak somewhere in the gas circuit.
Jul 07, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
I cannot get the auto self clean cycle to end
It sounds like your oven control module is bad. It conrols all bake, broil, including self clean.
Mar 25, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Noisy
Check to make sure the fan is not hitting anything, if the fan looks good then on the back oof the unit is a relay, check that and make sure all is well. If both check out ok then I would get to work on the compressor and make sure it is not HOT to the touch and that it is operating correctly.
Please rate and let me know if you need more help
Feb 09, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint refrig 21 cf over and under
Of course it can be plugged into a GFI outlet. Sounds like you have a compressor problem.
Nov 24, 2008 | Hotpoint HSS25GFP Side by Side...
Re; hotpoint refrigerator
probably the blades are hitting something , slide the fridge out and inspect, as far as it running all the time, many fridges run a lot more often than you think. the fan being noisy is drawing your attention to it more now.
Mar 24, 2008 | GE Hotpoint Top-Freezer Refrigerator
Hotpoint hts17gbserww
The problem you describe could be caused by a lot of different things. To start with, is the fan in the freezer running?
Dec 30, 2007 | Avanti FF1101W Top Freezer Refrigerator
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Avanti FF1101W Top Freezer Refrigerator Logo
354 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
