Cars & Trucks Logo
Anonymous Posted on Aug 26, 2011
I was changing the spark plug wires on my 1992 ford ranger. one at a time.one wire came.i got mixed up i need to see a picture of the wiring from distributor to engine block
Anonymous
Level 3:
  • Ford Master 3,640 Answers
  • Posted on Aug 27, 2011
Anonymous
Ford Master
Level 3:
Answers
3640
Questions
6
Helped
1674551
Points
10518
What size engine! ill type you a little diagram....
Front of vehicle
coils
3 1
2 4
4 2
1 3 this is for the 2.3, ill type you a little diagram....
Front of vehicle
coils
3 1
2 4
4 2
1 3 Just match the numbers you have on the coils to each side of the block? 2.3 engine
1helpful
87 ford ranger wont start replaced pulugs and wires
Common Sense - tells you that replacing spark
plugs & wires,while they may be an issue, or due
to be replaced,they won't all fail at once & cause
a no start
You need to check for fuel pressure at the motor
with a gauge & check for spark or injector pulse, while
cranking the motor with the starter.
Compression has to be on all cylinders & any timing
belt or chain in place & working correctly
Ford Ranger does not have any acceleration?
cam shaft or timing belt wore out
I have a 2003 Ford Ranger 3 liter. I just changed
Did you replace the wires? if not you may have broken a couple of wires. Not sure what fire wire is unless you mean the spark plug wires. Also did it do this before you replaced the plugs? need to know.
3helpful
How to change spark plugs on 1997 ford ranger
Changing the spark plugs is a pretty easy task. The spark plugs run along both sides of the engine (if its a V block) , 1 per cylinder. You can easily identify them by the plug wires running to them from the distributor. Pop off each plug wire, (1 at a time) and replace the spark plug. Once you have replaced the plug, replace the plug wire. This ensures that you dont mess up the sequence of the wires which determines which cylinder fires at what time in the cycle. VERY important not to mess up the sequence. If you should happen to get the wires mixed up, look online for the firing sequence for your vehicle and engine.
3answers
I just put spark pluges in my car and now it wont start it would start fine before the plugs were changed
DID YOU CHANGE PLUGS ONE AT A TIME ,IF NOT YOU COULD HAVE MIXED UP PLUG LEADS HAVE A LOOK TO SEE IF THIS HAPPEND.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
