Question about Nintendo Wii Fit for Wii
Power when turning board on light flashes a couple of times then goes off tried new batteries even power pack no joy
  • 5 more comments
  • Anonymous Sep 09, 2008
    When I turn on wii fit board the blue lights on the switch flash 3 or 4 times then it goes off. I have tried new batteries and synchronising but the problem remains. any ideas?.
  • Anonymous Sep 20, 2008
    We have the same problem. Blinks and goes off.
  • bumblebea Sep 22, 2008
    I have exactly the same problem, and returned it to the shop I bought it from who returned it to nintendo. 2 month laster it has returned with the same problem with instruction on how to sychronise!!! Still does not work! what are we doing wrong any suggestions PLEASE
  • Anonymous Mar 19, 2009
    I can press the power button on the board and it flashes on turns off
  • Anonymous Apr 18, 2009
    my wii isnt recognizing that the disk is even in the slot and when i press the power on the board it flashes on and off and then turns off... but the main problem is that the wii isnt even acnoleging that theres a disk
  • iloveyoux3 Apr 30, 2009
    The board has a flashing light and then stops. i even changed the batteries. help!
  • 2 Berds Jul 31, 2013
    Thanks, ibesushi's instructions worked for me
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Posted on Dec 09, 2008
After posting my message here I started to fiddle around with the wii fit again and went slowly step by step through the synchronisation steps. Voila it works! what I had done wrong was that I did not press the red synchronisation button for the wii console when the blue lights (after pressing the sync button) on the wii fir board started to flash. you must do this when they are flashing. Hopefully you are as lucky as me and it will work for you too.
Posted on Sep 29, 2008
I have the same problem as above when turning the board on the light flashes afew times then goes off like above have tried new batteries and power pack any ideas
  • lilah078
    lilah078 Feb 17, 2014
    I've tried all these steps but the light still won't stay on and sync with the wii console.....any other ideas?? Getting ready to take this board back and order the official Wii board!!
Compaq nx6110 PC Laptops: When i turn it on the lights flashes then goes off...
Which light flashes? If it is the battery light then perhaps your battery is empty?
When plugged into your PSU does the power light turn on? If not your PSU may have broken or the plugs fuse may have blown.
Other potential causes could be your RAM, CPU or even your system board. Check the RAM is correctly seated, if two modules are installed try removing one.
Hope this helps, www.PuterCare.com
May 17, 2010 | HP Compaq nx6110 PC Laptop
My PSP will not turn on unless it is plugged into the outlet. When I try to turn it on by itself the power light flickers green for two seconds and then disappears. Also, the battery is fully charged. When...
replace the battery as it may be out of CYCLES even tho it says its fully charged if the battry is new your going to need a new element inside usually this consist of a new logic board under the battery pack.
good luck
Apr 27, 2010 | Sony PlayStation Portable (PSP) Slim...
Toshiba Equium laptop not powering up.....dead!
hardware problem chech the board.. maybe the regulator is damage.. need to change.. if you can't do just bring to certified laptop technican.. to fix your unit
Jun 11, 2009 | Computers & Internet
Technika tv
hi everyone I think this is the answer you are looking for :- In order to get the TV working again there are 2 options = 1 buy a new aux board. 2 replace the compacitor.
Aug 19, 2008 | Televison & Video
Hi-- This is actually a problem with the Canon LK-51B battery pack that goes with the iP90v portable printer. We've charged up the battery pack and all the lights have gone out, indicating full...
electronics should not be relied on to realy confirm u need to use a second battery pack to connect ur printer n see if the same thing will occure. i guess the battry inside d pack may be dead even though its a new one.
May 24, 2008 | Canon Office Equipment & Supplies
It wont turn on
Hello
First, you must be certain that your battery pack is still good.
You have to clean all connecting point (between the camera and the batterry) with a dry clean cloth inside the battery pack compartment.
Another think to check, is the date and time battery (dime size battery located inside the battery pack compartment) to remove it, slide the battery case out and change it. Since the battery is install at the factory, it verry possible that there is no more power. At the end of your owner manual, you will find, before troubleshooting section, the way to remove it, it verry easy, no force need it.
A deffective flash card can also cause the problem. Remove also the flash card and replace it by a new one or another one that you have.
When the battery is fully charge, install it along whith the new time and date battery. Leave the camera alone for a couple of hour in order to let the board get some refresment. Try to put it on, if it not work, slide in and out the battery, couple of time, close the compartment and try again.
In many cases, the camera will start and you will have to put the time and date, if the battery (time and date) was warn out. Make sure that your screen is on. You ready to go. :)
Feb 15, 2008 | Canon PowerShot G5 Digital Camera
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Startup problems ctnd
It can be the memory, the board , the processor, the switch and alot more. A pinched wire. Just try one at a time with new or used working parts.
Jul 21, 2006 | HP Compaq Motherboard
Nintendo Wii Fit for Wii Logo
1,751 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
