Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Will not fax
Brother Copier/Fax MFC-465CN displays Poor Line Condition/Out of Memory message
  • rismall1950 Mar 27, 2009
    Poor line condition/out of memory
How do i find my fax number on my mfc-440cn?
Posted on Oct 05, 2008
OUT OF MEMORY
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-J5910DW printer wont fax
That message usually means you are not connected to a "live" phone line. Make sure the line is "hot" -has dial tone. Be sure that you have the line plugged into the correct opening marked "input", not the one that you plug a phone into.
Feb 28, 2013 | Brother MFC-J5910DW Color Inkjet...
Message: POOR LINE CONDITION / OUT OF MEMORY HOW DO I CLEAR THE MEMORY?
press menu *2864, display will flash if entered correctly, then press 91, then 99, memory should be cleared
Aug 16, 2011 | Brother MFC-8220 Fax
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
My Brother mfc-665cw will not fax. It keep saying NG: POOR LINE CONDITION/OUT OF MEMORY
Check to see if you can make a call using the fax machine. This error can occur if you have no connection. It can also occur if your line is occupied or busy.
Oct 14, 2010 | Brother IntelliFAX 5750e Laser Fax
I can not clear the memory MC-465CN on the fax - this is a mulitple function Brother - copies, scans, faxes,photo
If you clear the memory, any faxes stored will be also be erased. This solution assumes that you have the fax storage option "On" to store faxes in memory.
On the control panel:
1) Press <Menu>
2) Use <Up> or <Down> arrow keys until "Fax" appears on the display, press <OK>
3) Use <Up> or <Down> until "Remote Fax Option" or "Advanced Fax Operation" appears, press <OK>
4) Use <Up> or <Down> until "Off" appears, then press <OK>
5) You will be prompted: "Erase all fax?" 1. Yes 2. No
Press <1> to erase all faxes in memory.
6) Press <Stop/Exit> to return to normal function
Jan 29, 2010 | Brother MFC-465CN InkJet Printer
Our MFC 7840 printer when faxing keeps saying
Depending on your location the line coulod well be poor quality for a sensitive fax. Any spurious sounds on a fax line will cause it to fault.
May I suggest you try the fax on the mainline first before assuming the unit is at fault.
Length of line from point a to b can also reduce the efficiency of signal. It may sound ok to the ear, but resistance may be the factor in reducing the level of the tone that the fax requires to hear and then activate send or receive.It reports poor line condition and even poor memory because it keeps loading to send.
If it does it on the mainline as well then I would be considering a technical call for help. There may be a fault in the unit.
please rwte my help++++Thanks for using FIXYA
Nov 24, 2009 | Brother MFC 7840W Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
528 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
