Back to:
Tags:
Panasonic SC-AK630 CD Shelf System
CD Player (by 14 users)
posted by dougpw on Mar 13, 2006
Getting "no disc" error msg everytime a disc is inserted. Tried all disc's through the stacker and many different disc's. Disc's are clean. Have opened the box and cleaned the lens, but still same problem.
The disc is'nt spinning after loading. Lokks like either the lens is'nt funtioning or the disc motor is'nt working.
Thanks in advance for any ideas
regards doug
Comment by dougpw, posted on Feb 13, 2008
Luckily the unit was still under warranty when I had this problem.
So it was repaired by replacing a faulty PCB by an authorised repairer.
Sorry I cant help with any costings.
Cheers
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
13 Other Users Have The Same Problem
Comment by vtmlaw, posted on Jul 06, 2008
same problem, not under warranty. any help?
Comment by Guest, posted on Jun 19, 2008
even when discs are loaded & a disc name appears, volume is up, get clicking sound that's all & then it goes into cruise & the no disk message appears. Also when I hit play on the remote the drawer opens.
Comment by Guest, posted on Jun 01, 2008
MESSAGE "DISC EMPTY" USED CLEANER DISC, SHUT SYSTEM DOWN(UNPLUGGED IT FROM ELECTRICAL OUTLET) PLUGGED IT BACK INTO OUTLET. GOT THE SAME MESSAGE "DISC EMPTY"
Comment by girl lost, posted on Apr 02, 2008
I really need help with fixing my stereo, it is a ( AIWA nsx-5111 digital system and its got rotary changer system ) It use to work fine but one day one of the disc changer stop playing I open the stereo and cleaned it out and it worked fine but then another time they all stop working it just say no disc when there is a disc inside and now I don’t know what to do, there was also a lot of oily stuff inside. Is that good or bad? because I cleaned out some of it, but I don’t know if I should have left it. PLEASE PLEASE HELP
Comment by MoniGee, posted on Feb 27, 2008
My System gives me either "ERR" or "Disc" on the digital Display Window, tried every CD, cleaned the Lens, still the same Problem!! This is happening since I bought the Stereo System a few Days ago-from another Person, but still brandnew in the Box.. What else can I do? I don't have the receipt for it.
Thanks, MoniGee.
Best Solution
posted on Mar 14, 2006
FixYa! (100)
silly girl
Rank:Wiz Wiz
Rating: 81%, 3302 votes
You're probably right to suspect the motor, since its not spinning, and the lens is clean.
I recently had a "no disc" error that was fixed by general mechanic maintnance- taking apart the lens mechanism, cleaning, oiling and putting back together. If youre lucky it could also be your problem, and it should be a minimum repair fee.
Good luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on CD Player:
I don't want to Accept this solution
Solution #2
posted on Mar 08, 2008
Not Rated (0)
iggybug
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I just bought this stereo used today, and it wouldn't play--I opened up the back (you have to take out EVERY screw) and a CD had fallen below the CD changer and above the CD reader. I removed it, and now my CD player is perfect. Very easy fix, and it'd be hard to break anything doing it.
Thank You!
Solution #3
posted on Feb 20, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
i had this problem with many stacking hifi's if it still dont work after a good clean, laser,etc it usually means the laser has given up on life
Thank You!
Solution #4
posted on Feb 12, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Could be the program you are using for burning the disk. That is what it was for me. Use Roxio.
Thank You!
Solution #5
posted on Dec 03, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
we have found this to be the 16 way flat flex connector. failed where it was folded on exit of the cd drive.
Thank You!
Solution #6
posted on May 06, 2007
Not Rated (0)
anthony415
Rating: 90%, 1 votes
I get the same error and I took it apart. Looks like the motor doesn't spin at all. How can I fix this? Or how can I get a new drive or motor? How much does it cost to get it fix?
Thank You!
Can you Help with these Audio Shelf Systems problems?
Audio Shelf Systems
no longer plays cd's or cassettes( I know, it's old, so am...
Audio Shelf Systems
Looking for manual and where I could purchase a remote...
how do I program my cd player to play CDs in the stack or...
i have a xl pro and my disc player does not seem to read...
When I turn on my stereo and the bass hits really hard...
13 Other Users Have The Same Problem - Continued
Comment by Merlin1940, posted on Feb 07, 2008
I didn't know others had exactly this same problem. I bought my 2×25w RMS "AIWA MICRO HIFI COMPONENT SYSTEM XR-EM550" for 159 EUR in Dec 2004. Played fine, but a few months ago the CD stopped working: inserting a CD results in "NO DISC" message, motor doesn't turn. Mine is dusty, so I cleaned it (including lens), no avail. Still works perfect now (Feb 208) for everything else: RDS FM, or connecting my PC to its (excellent) speakers, or various functions (like waking me with nice radio every morning).
michel.merlin@laposte.net
Versailles, Thu 7 Feb 2008 16:22 +0100
Comment by Guest, posted on Jan 22, 2008
I NEED TO SERVICE THE BELOW MENTIONED CD PLAYER IN INDIA. COULD YOU HELP ME WITH SOMEONE WHO I CAN APPROACH AND SET THE PROBLEM RIGHT. I AM IN INDIA - MUMBAI ( BOMBAY )
Comment by Screwmaster, posted on Dec 28, 2007
I have the message "no disc", even though a good disc in inserted. Please help.
Screwmaster
Comment by CJ1984, posted on Dec 17, 2007
Having the same problem. My CD disc cleaner always did the trick with my computer and my commercial sound system but not this home stereo system. So, you are saying to take this to a repair shop and it should cost a minimum fee?
CJ
Comment by pamalamba, posted on Dec 15, 2007
CD player won't play CD's
Comment by Guest, posted on Dec 05, 2007
my cd do not working and dvd
Comment by Guest, posted on Dec 01, 2007
disc not finalized message comes up every time a disc is inserted. I have cleaned the lense but still am having the same problem. The disc will spin as if it is going to start playing.
Comment by Guest, posted on Nov 27, 2007
CD player reads "No Disc" when CDs are inserted. Also I need a diagram of how the belt should run on the turntable.
Loading problems.
Repair Service
Find Audio Shelf System Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
