Volume turns on and off - Televison & Video
  • 1 more comment
  • bareftbabe1 Sep 09, 2008
    sometimes there is sound and some times there isn't.. when it's working it's on for about ten minutes then the sound turns off... if we leave the tv off for awhile sometimes the sound returns.
    I've already unplugged it for about ten minutes and then restarted the it..
    I think I have fixed the problem.. I went into the audio menu and changed somethings around and the volume returned.. So far it hasn't shut off again.. Thanks for your help.. Hopefully I won't be back soon! :)
  • 4,234 Answers
Since you have not provided a make and model, I can not give you details, but based upon you r description, the likely cause is teh overheating of hte audio output amp chip. I suspect that tehre is perhaps a bad connection on one of the pins which is causing the chip to work too hard which generates excessive heat forcing a shutdown. If you open up the unit and look where the speaker wires connect to the board, there should be a small part that looks like a transistor but has about 6 pins. It may be attached to a heat sink as well. Check the connections at the pins. If they appear grainy or have rings, resolder them.
Let us know if that resolves the problem.
Thanks,
Dan
Posted on Sep 09, 2008
    President:
  • 1,952 Answers
Sound card pro in ut television mother board...change tat...it ll cost oly 250 to 500
    Master:
  • 726 Answers
It sounds like a fault has gone wrong in the tv , just check if any of the buttons are pushed in or even take the batteires out of the remote and see if it does it if it doesent its the remote
    Sergeant:
    Champion:
  • 331 Answers
If  it is the tv's problem  open it up an check the connections maybe it is loose
or it might be getting heated up.......
    Brigadier General:
  • 6,966 Answers
Depending on several factors, intermittent audio could possibly caused by:
  • SAP, MTS, audio setting/configuration;
  • hardware fault, most likely a cold/loose solder/connection;
  • muting button on the front panel loose/vibrating;
  • firmware glitch.
Initially, pls try to:
  • reconfigure audio menu;
  • check signal sources, cable, sat/cable box, DVD;
  • check cable connection coming into the TV;
  • try other signal sources;
  • do a reset, unplug from the mains for a few hours.
If the fault is internal/hardware, this of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 435 Answers
First try to restart the tv after unplugging it.
Also , it could be a problem of defected button or switch.
Thanks
  • 19,396 Answers
Start unplugging power cable for ten minutes, see if this clears the error.
If it did not fixed check the touck button on fromt tV panel, it is probably a faulty button.
  • 2 more comments
  • Ginko
    Ginko Sep 09, 2008
    If volume shows erratically behaviour do the following:
    • Take batteries out from remote and check if it is a remote problem.
    • Try pressing and playing volume buttond on TV, see if it can be a button.
    • If it is a button remove front panel and clean button contacts with circuit cleaning solution.
    • If all the above did not work, it is either a faulty control panel or a faulty audio pcb on your tv. Them both must be tested (control panel it is an easy test if you know how to use a multimeter)
    If you need replacement parts enter model here
    If you need to call a technician you can ring the number listed on your owner manual
    Other way to fix it.... you give model number to Goldflack and he will magically fix it...just kidding, read reccomandations above, and let me know if you need further help.
    Vote the solution that you repute most helpful among ours or goldflack will get the...model number..
    Many thanks.
  • Ginko
    Ginko Sep 09, 2008
    Then it is not volume turning on and off, you have a lose connection to the tv speakers.
    This is probably an easy repair, as it will require re soldering the broken contact.
    Unless you are experienced in repairing TVs you should call a technician.
  • Ginko
    Ginko Sep 09, 2008
    If wiring and contacts are ok you may need to have the audio board inside replaced.
  • Ginko
    Ginko Sep 09, 2008
    If the TV has a jack headphone socket, try also plugging in and out headphones, see if this affect the problem, if it does then the headphone socket on TV is faulty.
    Sergeant:
    Champion:
  • 310 Answers
PLs tell me model no and company name
How do you turn up the volumes when people call
Nokia 2610 how do you turn up the volume - Microsoft Community
answers.microsoft.com/.../nokia...do-you-turn-up-the-volume/ba9fa2aa-...
Jan 9, 2008 - Hi I have recently purchased a Nolia 2610 and on some of my calls I canbarely ... I have tried to find a way to increase the listening volume on the ... Nokia2610 how do you turn up the volume ... 17 people had this question. Nokia Lumia 635 - call volume is too low, can't hear
Jun 27, 2015
Nokia 220 dual sim - call volume problem
Jul 23, 2014
1650 how to change call volume?
Dec 29, 2008
More results from answers.microsoft.com
Adjusting the sound of a Nokia phone - CCM
Feb 03, 2016 | Nokia Cell Phones
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
How do I turn down the volume on DVD portable Sylvania without remote
To turn the volume hold down the play/pause button
To turn the volume down hold down the stop button
Aug 31, 2014 | Sylvania SDVD1030-RED 10-Inch Portable DVD...
I want to increase its speaker sound and ear piece sound but i dont know how to
Volume keys: These keys allows you to turn up or down the volume of the ringtone and the speaker. Press these keys to turn the volume display on, and to change the volume.
To lower the volume of the ringer during an incoming call, press the down volume key to the desired volume, or until the option changes to Vibration All Activated. The volume keys can also be used to scroll up or down to navigate through the different menu options. These keys are also
used when the Music Player is active. While on call turn on the speaker and increase the volume with the Volume Key.
Jan 16, 2011 | Samsung Cell Phones
Acertravelmate4000 got it used,don,t know how to turn off mute,turn on or up volume
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
The volume level may be too low. In Windows, look at the volume
control icon on the taskbar.
Fn-? Volume up Increases the sound volume. Fn-? Volume down Decreases the sound volume.
If this helps u let me know
regards
Jan 12, 2010 | Acer Computers & Internet
The volume is low when the volume is turned up to?
Turn the volume down and turn off the tape2 or tape monitor.
Dec 08, 2009 | Audio Players & Recorders
Volume is too loud
change the function to cd or aux before you turn it off and then change the volume before going to your preferred function. It is the only way around it.
Mar 16, 2009 | GPX HM3817DT Shelf System
Volume level
On this model it has a preset volume when it comes on. To change the preset volume press and hold the volume button on the reciever you will hear a beep or 2 and poof its done.
Mar 06, 2009 | Jensen's VM9312 Car DVD Player
Volume Issue with CD Player by Durabrand.
it just seems a setting problem.
go to AUDIO SETTINGS or MENU.it will have "ON VOLUME".
press volume control -ve to get desired volume.
press AUDIO or MENU to store volume level.Next time u turn it ON ,the volume will be what u SET. OK i hope this solves your problem.
Mar 24, 2008 | Audio Players & Recorders
Dont know how to turn the volume up on this headset
turn your headset off. when you turn on yourheadset back on , push the volume you wish to control the volume with. this buttom you choose shound be your volume up button now.
Aug 31, 2007 | Motorola Mobility H350 Wireless Headset
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
