Question about ASUS A8N-E Motherboard
No audio alsndmgr sense front connector failed pc showing messege
The asus motherboard is not accept other sound driver
Posted on Sep 09, 2008
775 audio conection are fine but no sound from front panel
You need to go in the Sound setting control panel and disable the sensing - or enable the front connectors permanently, depending on what sound chip you have.
Jun 21, 2011 | Computers & Internet
I have an xw9400 board on a normal case,after connecting usb on board with the front panel,board still cant recognize front USB,i need to change wires in the connector to match the board,same thing with...
The front USB header on the XW9400 board has a ground connected to pin #10. The USB standard #10 pin has nothing connected to it, so HP uses it to sense whether a connector is attached to the header.
Apr 01, 2011 | Computers & Internet
I have hp laptop.there is downloding problem from any site.audio or vedio.the messege is showing that your seccurity setting is not allowing to downlode.how it will solve?
If you have antivirus or internet security suite check it. Also go to Control panel and check on Window defender and Window firewall.
Oct 27, 2010 | Computers & Internet
Not audio from de front , went i plug audifon fron the fron theres no audio
That's cause the front audio connectors are not connected.. To do this open up the tower.. Now locate the wires from the front connector.. Its labled j audio.. Now on the main board there is a jack for it,, some pins labled audio as well if its not labled then look for the pins in the same fashion of the jack.. If u see some plastic jumpers bridiging 2 pins remove it.. Plug in your front audio connector.. That's it your done..
Aug 03, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
Show me where the printer should connect to the back of dimension 3000 tower windows xp
google for dell dimension 3000 and you find the manuall see below i found it on :
http://support.dell.com/support/edocs/SYSTEMS/dim3000/en/SM/index.htm
Connectors
External connectors:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Network adapter
RJ45 connector
PS/2 (keyboard and mouse)
6-pin mini-DIN
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Audio
three connectors for line-in, line-out, and microphone; one front-panel connector for headphones
Mar 12, 2010 | Dell Computers & Internet
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
Parallel
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
Hi i have a problem connecting the front pannel mic and standard audio connections to my winfast k8m890m2ma motherboard the manual shows where the 8 pin "front audio connector" is like this...
It is a bit of a problem when you have single connectors but here goes. You use the Front Audio connectors. The manual says you have :::.:
If you turn the board round until the dots are the same way round as above. Working from left to right.
Bottom row. MicIn, MicBios, SpkoutR, empty,SpkoutL
Top row GND, empty, returnR, blank space, returnL. Now this is the tricky bit. Try the power if it works OK. Because the board and the case manufacturer work to different descriptions, try this as an alternative. You may have to swap over the two connectors for GND and Mic Bios.
Mar 10, 2008 | Computers & Internet
Audio outputs doesn't working
It sounds like a motherboard sound chip failure, although run a diagnostics on the sound, click Start>run, then type 'dxdiag', hit 'Enter' and run sound driver test. If it has failed, you can purchase a cheap PCI slot souncard and dissable your onboard sound, or a complete new motherboard.
Jan 04, 2007 | ASUS A8N-E Motherboard
ASUS A8N-E Motherboard Logo
295 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Tony
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
