Question about Datamax M-Class M-4206 Thermal Label Printer
Datamax M-4206 - error light whenever load or print labels
We have had the above Datamax label printer for a few weeks now and I have never been able to get it to work. We need to print on labels that are 18mm x 25mm. As soon as we load the labels and press the feed button as per the setup guide the error light comes on. We have to recycle the power to clear it. Also - as soon as we try to print anything (we are using Labelview 7 - I set the size to 18mm x 25mm etc) - it prints one and then feeds through another 5 or 6 blank ones and then the error light comes on. Again, I have to recycle the power to clear it
Any help would be greatly appreciated
Many Thanks
Kev
  • haroonfoad Sep 19, 2008
    I have exactly the same problem please any help.
  • 155 Answers
Perhaps the sensor is out of position, you must move to the left. Also check that the hole senser is not blocked. Also verified that the sensor type (gap or black mark) in the software is correct.
Posted on Mar 16, 2009
What is the backing?
The Backing is the see through paper on which the labels are stuck to. It can have a light yellow or white color. While the printer prints, the labels move through the label sensor, usually green in color. The gaps between the labels triggers the sensor to indicate where the printer should start to print.
Hope this Helps. (",)
Aug 05, 2014 | Datamax DMX-M-4206 Thermal Barcode Label...
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
Can not find driver for a meto 4206 thermal printer? where can I get a free one
Free Windows Printer drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
Feb 07, 2011 | Datamax Office Equipment & Supplies
We have just gone live on sage 1000 and are trying to print labels designed in sage paperless to send to our Datamax m-4206. Labels print but we cannot get the information to line up on the labels. Is...
This can be caused by either the software, or the printer's electronic or mechanical settings. Software will usually override the printer settings for print speed, temperature, label dimensions, etc. In order to fully diagnose, I would need to know if the print is too high, too low, too far left or right, or skipping a label, etc.
Nov 08, 2010 | Datamax M-Class M-4206 Thermal Label...
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
I need driver for datamax m 4206 e mark II
Jun 16, 2009 | Datamax M-4208 Thermal Label Printer
Datamax dmx-m-4206 printing half of the label
check for the flatness of the printhead across the platen.
also check to see if the head is not worn(will be white colored at the head heat elements.
also check to see if the platen is severly worn.
Jan 15, 2009 | Datamax M-4206 Thermal Printer
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Aug 25, 2008 | Datamax M-Class Thermal Printer
Datamax M-Class  M-4206 Thermal Label Printer Logo
668 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
