I have a dell Inspiron 4000 and I cant get it to load when you turn it on all I get is a white screen will not load anything other then a white screen and I don?t know what to do to fix that problem if you can help me with this
-   mine is fine until log-in, once it tries to log me in it says the application failed to initialize and goes to a white screen, nothign else will happen.... HELP!-   danny-boi47
Jun 01, 2008
-   My 4000 powers on and will load, however after a while the screen goes white. Is the a Bios problem? or what?-   Guest
First, can it boot into BIOS setup? This is DEL, Esc, F1, F2, or whatever key your user manual instructs; press the requisite key immediately after pressing the power switch.
Second, can it boot from an emergency recovery disk from the floppy, or a boot CD from the CD drive?
ok, take out all devices from the computer, memory hard drive, battery,
and anything that provides power to the computer as well. hold down the
power button for 30+ seconds and put everything back in. then try
turning on the laptop. if you have any more questions, please email me
at meanness628@aim.com
After an accident with water it was dead for a month then slowly started to work. Now it can work...
(More)
After an accident with water it was dead for a month then slowly started to work. Now it can work for up to 30 min, then in a sec shuts down making loud noise which is coming from the fan area. One day it worked perfect after I opened it up and cleaned it. Then next day back to "normal". Vista windows are installed.
I need to enter criteria in a query for the yes/no field and have tried alot of ways to no avail....
(More)
I need to enter criteria in a query for the yes/no field and have tried alot of ways to no avail. Can you help me please?
