SL-hdv600 error code h02 What is causing this when I put a dvd in the drive, a cd will play for 30 seconds then stops
  • eileennorman Jan 11, 2009
    wont read CD, thinks about it and then says DVD HO2, then reads no disc.
2 Suggested Answers
TheQueue
SOURCE: panasonic DVD-RP56 Error H02
I read about removing the cover and spinning the motor by hand. It was suggested without power. I found that I had to have the unit powered up when I hand-spun the motor, then everything worked perfectly... we'll see for how long.
Posted on May 05, 2009
My technics sl-hdv600 will not play dvd or cds
Hi, have you ran a laser lens cleaner through it?
Nov 10, 2011 | Audio Players & Recorders
Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Sep 06, 2009 | Technics SC-DV290 System
Pana sonic home theater system Ho2 code
the problem be in the spindle motor drive circuit so you can solve it
Dec 24, 2008 | Panasonic Home Theater System System
Technics sl-dv 290
I think your dvd is set to a different region. This might help:
1. Insert disk
2.Wait for 'no play'message
3.Immediately press stop
4.It wi go to chapter review automatically in about 5seconds time u should be able to press play and start the movie
Hope this helps
Miss didi
Nov 01, 2008 | Technics SC-DV290 System
PANASONIC SA-HT800V
Ouch - This generally one of two things.
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
Aug 15, 2008 | Panasonic DVD-LA95 Portable DVD Player
H02 Error after inserting a dvd disk
The trouble started with an error to close and open the DVD drawer. It indicated "close" when the drawer was open, or "no disc" when the DVD was inside, and I had to try many times before I get the right response and go on with the procedures.
But then it also started playing just a few MP3 tracks and stopping to work, showing again the inserted DVD data. Later H02, and then H07 and STOP. It doesn't even start playing stuffs, movies or MP3 tracks!
Aug 11, 2008 | Panasonic Televison & Video
PANASONIC SA-HT800V
servo problems will need to replace dvd board...is that cost effective ?..replacement price??
Jun 13, 2008 | Panasonic sa-ht800V Home Theater Audio...
No Longer Plays discs
You should try this site. It worked for me. Also after fixing you should try and remove anything that may be on top of the DVD as this seems to cause the issue. We have had our S35 for at least 4 years and today was the first time I got the error.
http://wiki.xdroop.com/gallery2/v/Random/0706_001/IMG00104.jpg.html
Sep 01, 2007 | Panasonic DVD-S35 DVD Player
Error message when playing any DVD in Hi-fi
Feb 28, 2007 | Technics SCHD560 CD Shelf System
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
