Black & Decker TCM700 Coffee Maker
Problem for Black & Decker TCM700 Coffee Maker
Black & Decker TCM700 Coffee Maker problem
By MWitter on Mar 11, 2006
I just bought a Black & Decker TCM700 Coffee Maker, and it worked fine for 2 weeks. Now, the lights & digital readout work, but it will not heat the water either on "Brew" or "Auto-On".
Q: How can I diagnose the problem & fix it? Thanks!
Same Problem
Apr 28, 2008
-   Sometimes there are no thermal resistors (thermal fuses) just the cutoff switch. Make sure there is contact between the switch and the outside of the heating tube. There should be some di-electric grease or heat sink grease in between where they contact each other. That small amount of grease helps in heat transfer.-   Rambo_2
Feb 09, 2008
-   lasted 2 wks now it won't heat.
GRRR
Paul-   Guest
Solution #1
posted on Mar 11, 2007
Helpful)
kONk
Rank: Apprentice
Rating: 85%, 1 votes
the concept still applies. the heating element is usually dual functional. heating the water then keeping the plate warm.
Comments:
Mar 11, 2007
- the link http://home.howstuffworks.com/coffee-mak... is to a picture of the thermal cutoffs connecting to the heating element.
On the thermal cutoff in very small print will be the rating.
Goodmans is very inexpensive. You can get several delivered to you for less than $5. I know, I've done it.
Here is the link:http://www.goodmans.net/search.asp?p=1&w=%5F&c=thermal+fuse&t=s
Was this helpful?
Yes
No
Solution #2
posted on Mar 16, 2006
Helpful)
Gryz
Rank: Apprentice
Rating: 85%, 12 votes
All coffe makers have a thermal cutoff fuse located on the bottom heating plate. It is usually in series with one of the leads to the actual heater. This should read "short" with an ohm meter. If it is "open" it needs replacement. They are rated in Degrees celsius, and are sometimes difficult to find. Black and Decker may be able to send you one.
Was this helpful?
Yes
No
Solution #3
posted on Feb 17, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This is a thermal carafe, thus it does not have a heating plate!!!!!
Popular Solutions for Black & Decker TCM700 Coffee
Questions and Unsolved Problems for Black & Decker TCM700 Coffee
Do you recommend Black & Decker TCM700 Coffee Maker?
Answer
Answer
I love my large 6 cup Chambord Stovetop Espresso Maker, it works perfectly every time. Why can't I... (More)
Answer
I'm having trouble descaling my machine, the booklet says to remove the portafilter (I assume... (More)
Answer
took it apart to clean now can't put back together
Answer
I just bought a Black&Decker TCM700, but since the first use the coffee had a strange... (More)
Answer
Now have this B&D coffee maker but had the same problem with other brands. One out of every 5 or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Black & Decker TCM700 Coffee...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
