Question about Logitech X-530 5.1 Channel Speaker System Computer Speakers
Volume control on the master speaker
The volume control on my master speaker has unfortunately snapped off after falling off my shelf. It has broken away from the connections inside the speaker, and really would like some advice as to what to do, can i replace the specific parts and fix the volume control. Alternatively can I buy a new speaker separately to the rest of the set. I emailed the technical/product support division of Logitech and gained no further insight into my situation. Your advice on the matter would be greately appriciated Thanking you in anticipation Alex Bristow.
    President:
  • 3,130 Answers
If its a rotory type control simply take the rest out or off the pcb if you can and on the side of almost any varable resistor or pot is a value. Look to see if radio shack has that value or check your local electronic parts supply house and solder back into place But you may not get the exact one as they all have differant mechanical standards as the shaft may be too long or it may not fit on the pcb so you will have to drill into the cabinet and mount where theres nothing in the way and hook the wires to the control from where the old control was. Hope this helps good luck
Posted on Mar 24, 2006
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
Emerson Heritage Model # NR303TT getting very low audio from speakers, even with the volume all the up. Any help is apperciated. Thanks!
Sounds like a dirty volume control switch! If you could open the radio and look for the volume control inside, spray some contact cleaner if there is small hole on the metal cover of that volume control, after spraying play(side to side movement) the knob of the switch so that the contact cleaner would spread inside the switch. If that does not help, you should replace the volume controller switch with the same value.
A simple electronic technician could replace it.
Hope that helps you out!
Thanks for asking FixYa!
Jul 03, 2011 | Emerson NR303TT CD Shelf System
Hello, im using sony vaio VPCEB3J1E,speaker is not working but head is working,what is the problem?
For Vista/windows 7
Check with volume settings.
Right click on the speaker icon in taskbar and select volume control options.
Put a check mark on "All devices currently playing sound".
Make sure you have "The default communication device unchecked".
Place a check mark on both speakers and headphones.
For Windows XP
- Speakers, Headphones
In "Control Panel", select "Switch to Classic View", and open "Sounds and Audio Devices".
In "Sounds and Audio Devices Properties", click the "Audio" tab, and click the "Volume" of "Sound playback".
On the "Master Volume" screen, click "Properties" in the "Options" menu.
Add a check mark to "Playback" of "Adjust volume for" on the "Properties" screen, and check marks to "Master Volume" and "Wave" for the control to be displayed, and click the "OK" button.
On the "Master Volume" screen, remove the check marks from "Mute all" of "Master Volume" and "Mute" of "Wave".
Note: The settings may differ depending on the PC you are using. Please check items such as sound in the manual for the PC you are using.
May 22, 2011 | Computers & Internet
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
The speaker volume is too low. I set the bios to 8 and still the volume is very low
Volume for what? New laptops have the mixer effect in the volume pad... one can control video volume, internet broadcast volume, master volume (main volume level), and so on.. check that they all are all the way up (to the max) and controll it with the master volume regulator.
Dec 31, 2009 | ASUS K50IJ-C1 Notebook
Adjusting the subwoofer volume seperately from speaker volume
You can't exactly set volume but definitely turn down the bass which lowers the sub's output. Thats all we can do i think.
Mar 12, 2009 | Logitech Z Cinema 2.1 2.1 Speakers
Peavey floor monitor speakers
you can bypass the volume controller and use the master control. just take out the volume controller and splice the wires from there straight to master control.
Feb 23, 2009 | Audio Players & Recorders
Soundspace 5 Right Channel Problem
Some thing has broken in the unit! Switch speakers around to make sure its not a blown speaker! If its not the speaker then your right channel control will need replaced!
please rate answer!
Jan 24, 2009 | Nakamichi SoundSpace 5 Shelf System
No volume
maybe he invert the connection of speaker with the antenna wire-try also to make system reset (on-off)----remove power cabel and reinsert it check volume control in high level.
Jul 31, 2008 | RCA 100-Watt Stereo System With 5-CD...
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Logitech X-530 5.1 Channel Speaker System Computer Speakers Logo
159 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
