Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Loud Noise I still don't think I am explaining myself. The noise is only in the spin cycle, and it is kind of like turning on a fan from low speed to high speed as the the washer is spinning out. When it first starts to spin it is normal but the longer it spins the louder it gets. there has never been any banging noises.
  • Anonymous Dec 15, 2008
    machine spins really loud sounds like a jet.
  • Anonymous Dec 26, 2008
    Loud, constant noise during spin cycle. Drum rotates with a vibration, like it has a bad bearing or roller wheel. Same noise with drive belt disconnected and drum spun by hand.
  • 1,031 Answers
Okay If these efforts fail, Next, test the timer motor, inspect the pump for blockage (see below), test the machine motor.the sound during spin cycle may be due to gears on the motor shaft wobble, the bearings may be worn out or some of the moving parts may be misaligned.
its a sign that the motor, the rotor, stator, or brushes may be worn .or the motor is overheating and may require lubrication, the motor's windings may be wearing out
If the motor is too hot to touch, something may be blocking ventilation around the motor.
the , bearings may be worn out
Inspect the water pump for a blockage
Inspect the coupling
Inspect the transmission
Adjust the drive belt tension
Check the motor bearings
Check the drum brakes .
Posted on Sep 09, 2008
Duet washer making a loud noise on spin cycle, it squeaks on low spin and then when it gets up to high speed, it is really loud. What could this be?
In most cases it is something that is sticking between the drum and the housing. Check inside the boot by the door. If that is not helpful move the drum by hand and listen to see if you can locate the area of the noise.
Dec 30, 2015 | Whirlpool Duet GHW9150P Front Load Washer
My trton t90z makes a loud noise 15 secs after its turned off. Its the thermal switch. Should I get it replaced. Its 2 days old.
What makes u think its the thermal switch? normally the noise at beginning or end of cycle is caused by the compressor with bad springs, groumets, or not sure how to explain this but the freon sits in a round bowl like orifice and when its low there is usually a loud noise at end of and beginning of cycle. other words when goes off and comes on? ( this is usually due to moving the fridge on it side and not waiting long enough for oil to settle before turning on?
Apr 02, 2015 | Refrigerators
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
Nov 22, 2013 | Whirlpool Washing Machines
Loud whirring noise going into rinse cycle. Low
Hi tuck just read your posting.Now on the low whirring noise on the start of the rinse cycle ,Is it when the machine is draining the water or filling with water.If the noise happens when the machine is draining then I think either your pump has something slowing it down or it is faulty.Please look underneath the machine to the front right and you should see a red or black fan .If you do then this is your pump.If you don't see a fan you must have the newer style of pump.Please reply with additional information on the questions and I am sure I can help you rectify this problem
Jul 08, 2010 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
May 15, 2010 | Washing Machines
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Loud dry sounding spin cycle
cabrio and calypso have some issues with either main bearing problems or brake drive issues, either or this is an expensive fix, so if you have an extended wty, call your service provider, if not, just replace it, repair most likely in excess of 600.
Jun 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Samsung DLP TV is making a buzzing sound. Sounds like something spinning. Can hear it speed up to full spend when turned on and slow down and stop when powering off the TV. Loud at times.
More than likely this is the cooling fan. I have a Samsung DLP myself, and at times, I can hear the fan running also. There could be something wrong with the fan, but I kind of doubt it. Just make sure that the TV is in a spot with lots of ventilation....otherwise, you might have to live with this noise.
Hope this helps!!
Oct 08, 2008 | Televison & Video
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
179 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
