Question about Pioneer DVR-5100H DVD Recorder
Digital audio problems
I have my DVD Recorder connected via optical cable to a yamaha receiver. Lately the digital audio signal has been stuttering, regardless if playing from harddisk or DVD
My hdd 420h dvd/dvr is displaying hdd information error when ever i used hdd to play
Posted on Dec 17, 2009
  • 513 Answers
Try using a different cable for starters, regular rca, another optical or coaxial. If the optical works, then its a cable problem. If the coaxial works(and another optical doesnt), then its a cable/jack problem. If the RCA works(and the rest don't), then its a problem with the digital output. Try blowing into the holes, and if nothing works and you can't find any other advice, contact Pioneer. Good luck
Posted on Mar 14, 2006
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Can I connect component av cables "in" to my Yamaha RX-V365 and connect "out" to my TV and get both audio and video?
Receiver does support 3x component inputs and one component output. Both these can carry only video signal, not audio. So you have to connect audio separately, either stereo via analog 2x RCA connectors and digital SPDIC via optical (2x) or coaxial (1x) cable.
Feb 23, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Jun 05, 2009 | Yamaha RX-V463 Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
NO AUDIO/set up problems
For this Sony, you have to use separate audio cable(s). Either optical in BD or Digital Audio in DVD (single coaxial cable will do the trick) I bet the display says UNLOCK. I had the same problem, very dumb.
Good day!
Jan 19, 2009 | Sony STR-DG510 Receiver
No dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Pioneer DVR-5100H DVD Recorder Logo
166 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
