Question about Philips Magnavox 51MP392H Rear Projection Television
Rain bows how do i fix this problems? rainbows at top and bottom. showing double
  • keriro74 Sep 09, 2008
    i was told that it is two years old but i'am not sure. it is a little blurry color is not sharp it has a blue tint at top in the middle, what is the least amount that i have to spend to fix.
    Genius:
  • 1,139 Answers
Hello keriro74,
Your convergence amplifiers ICs have become defective, They will have to be changed out. They are usually marked with a STK392-110. You will have to also change out the fusable links connected to the STK392-110. Desolder the pins and unscrew the ICs and remove both of them. Then desolder the fusable liks and replace them with the new ones, then insert the new ICs and solder them in (being careful not to create solder bridges). Then you will have to perform the convergence on your TV, Try to use Auto-Convergence to do this.
I hope this helps
Thank you
Shuttle83
Posted on Sep 14, 2008
The picture is showing multiple images with red, green and blue rainbow effect. The picture is also bowed on the top and bottom
This is whats called a convergence failure. You will need to call in a repair shop or goto sites like www.TvRepairKits.com hthat ave the parts to fix this yourself. Its a common failure on projection TV sets.
Aug 07, 2011 | JVC AV-56WP74 56" Rear Projection...
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
Rainbow showing up at bottom and top of screen creating double and triple vision
IM GUESSING ITS A LAPTOP SCREEN OR COMPUTER IT COULD BE SOME WATER TRAPPED INSIDE OF THE SCREEN LIKE CONDENSATION WHICH COULD MAKE A PRISM OF LIGHT LIKE WHEN YOU SEE A RAINBOW BECAUSE ITS SUNNY AND RAINING
Oct 08, 2009 | Philips TV Tuner Video Capture PCI Card -...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Is my bulb going bad!!!!
Without seeing your Tv it is hard to say what is really going on.
The cloudy picture sounds like one of your "bulbs" needs to have it's fluid changed, not "bulb" replacement.
Rain bowing normally means convergence adjustment or circuit repair is needed.
May 25, 2008 | RCA P52926 52" Rear Projection Television
Zenith IQ6097DT 60 inch big screen
Convergence circuit repair plus fuse in the power supply,
usually 300.-400.00.....................if you are mechanically
able and can solder well,it is possible to DIY...................T.
Mar 31, 2008 | Zenith IQB50M90W 50" Rear Projection...
Help tv is showing double text at bottom and bowing colors
Convergence ICs are bad and need to b replaced there are two of them theyost about 10.00 each.
Jan 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 60PP920217F bows in on top and bottom
convergance amp ic are bad.
Nov 28, 2007 | Philips 60PP9202 60" Rear Projection...
3d/rainbow affect
Sorry to tell ya Gemini, but there are no user serviceable parts inside a TV set unless your a technician as theres several safety issues of Hi Voltage involved as well as unsoldering and soldering. You Have a convergence problem or Pincussion issue with your set. No quick fix for this one. You need to call in a pro to assist you with this repair. Good Luck
Jul 15, 2006 | Samsung PCL6215R 62" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
