Question about Panasonic SC-AK220 CD Shelf System
Cd jam the door for my cd changer, is not closing, it goes in half way, sticks then comes baq out. i cannot get the other cd's that are in the system.
    Scholar:
  • 124 Answers
Try dismantling the shell and check for any jammed object or broken pieces that might cause the door jamming. if it is a matter of a stuck object that somehow got there, you can remove it and hope for the best. otherwize, you will have to replace the broken pieces, or the whole part.
Posted on Mar 14, 2006
Cd was still player and I found the player with drawer half open and jammed. I can't get it to sync with correct rotation, enough rotation or fully close or fully open. I can force it and hear the gears...
Rea alligning cds is not hard, but not too easy,the best way is to remove the whole cd changer mechanism and allign it to either one point,while totally disconnected, fully open or fully closed. I mean, the rubber or gear mechanism.
The main point of reference is the nearest part driven by the main motor. For example decide to do it when fully open, arrange everything so as to allow the tray to be fully open.If you get everything right, rotate the motor manually and see if it closes the tray without jamming..If it gets fully in keep rotating the motor and see if it loads the disc.if it does, return the assembkly, the sensors and the cd computer will take over from there ...
Apr 12, 2017 | Sony CDP-C445 5-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Error 3 comes on display when I press disc button to play a cd. cd will not play, cds will not eject
It's one of two things; more than likely the cartridge is jammed, meaning it tried to return a cd in a slot where there already was a cd stored and has jammed half way. The way to confirm this is to open the slider door to the cartridge, use a good flashlight, and try to see if a CD is "half in- half out" of the transport. Don't force the CD into the cartridge or transport. What you have to do is pull the unit out of the car, take out the screws on the sides and top if any and take the top off the player. Now you can see exactly whats wrong. if there is not a CD in the transport, gently push the cd into the player, freeing it from the cartridge. Now plug the unit back in with the top off and watch the mechanics, it will automatically reset itself. once this is done, eject the cartridge and carefully look at it for bends or warps, if you find any, replace the cartridge before you use it again. They just get warped over time and vehicle heat and is a very common problem. Hope this helps
Jun 07, 2009 | Car Audio & Video
6 disc changer will not eject cds==
I had the same problem for months. I checked the owners manual, checked the fuse box, everything I could think of. Then, today, I did some online research and someone said one of the CD's is probably just jammed or slipped out a bit. The suggestion was to gently slide a credit card over the disk (through the door/slot, which in my case was partially open). I just tried it. The door closed and the message said "initializing". It worked! The CD player is back to normal.
May 24, 2009 | 2005 Mercury Mountaineer
How do you un-stick a cd from a 3 cd changer
Unscrew the top of the unit and then you should be able to access the cd that is stuck. Then you might have to play with it to get the CD out of the reader.
May 02, 2009 | Sony Car Audio & Video
My pioneer 100 disc cd changer (Pdf906) door gets stuck when opening and closing. I haven't used it in awhile kinda sounds like it struggles half way through of both opening and closing the front part.
my pd f100 disc pioneer is blinking and the first 25 disc compartment was sticking...i opened and found the main loading system was in the way of the 25 disc compartment...the compartment was rubbing on the loading system...i am trying to back up my loading system without breaking to re start the process and stop blinking...if anyone can help let me know...marc---- yours is probably starting to rub....also,the sping under the compartment needs crazy glue so it doesn't shift....that is another sticking factor i found on mine also.the spring wants to move underneath... open your panel and make sure not to touch any circuit boards...some of them --you have to be grounded or you'll fry it....
Mar 05, 2009 | Pioneer PD-F906 100-Disc CD Changer
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
I had a cd jam,took cd changer apart, now the door won't close all the way
Hi artzelda
The machine tray carousel may have stepped out of alignment after jamming on the dislodged CD and is catching on the CD transport assembly on the way in. on the way in. This problem can generally be solved by retiming the tray mechanism. This is one of those jobs that takes some perseverance and an understanding of the transport. If you don't have a head for mechanical things, this may not be something you can fix yourself. A HiFi repair guy would. Should be minor charge.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jul 06, 2008 | Harman Kardon FL8385 5-Disc CD Changer
CD jammed in player
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent. regards Mark www.carradiospares.co.uk
Aug 05, 2006 | Alpine CHM-S630 6-Disc CD Changer
Panasonic SC-AK220 CD Shelf System Logo
116 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
