Question about Brother MFC-465CN InkJet Printer
Brother MFC-465CN wont print
I have just bought this printer and it shows as offline in the status monitor I have tried many things to bring about recognition but the pc wont pick up the printing function of the MFC. I can scan and pull photos from the printer. Help!
I had a similar problem, and it was due to the IP address not being properly set during installation. (Note, I installed it as a network printer. If you installed it as a USB printer, this won't work) Try this:
Select Start->Printers & Faxes, a window comes up, hopefully your Brother printer is one of the printers.
Right-click on the printer icon and select properties
Select the "Port" tab in the window that comes up
One of the entries should say "Standard TCP/IP Port". Click on that entry and click the "Configure Port..." button, a window will come up.
In the "Printer name or IP address" field, you may have a name here instead of an IP address. (Mine was "BRN008077E21669") Change this to the IP address for your printer. You can get this by navigating the menu on the printer (Under LAN->TCP/IP). I changed mine to 192.168.1.80, since that's the address I configured my printer for.
Hit OK and Apply in the open windows and hopefully you wil be in business. Good Luck!
Posted on Sep 27, 2008
Why is my printer offline
Try it...
Double check the connections and also check status from device manager.
Go to Control Panel
printer and Faxes and right click your printer and just click set to online
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 14, 2013 | Brother MFC-465CN InkJet Printer
My brother printer model mfc 465cn, it has ink but the print its not coming out, dont know what to do
try cleaning the carriage assembly. the that the ink is installed at. then do the print alignment at the printer settings.
Jul 02, 2010 | Brother MFC-465CN InkJet Printer
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
Brother MFC-7340 Status monitor offline
Is it giving any errors when you try to print?
Sep 22, 2017 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Jan 20, 2010 | Brother MFC-465CN InkJet Printer
Brother mfc-465cn opening raster file failed
Try downoading the drivers from the apple web site. You would need the brother 1.1 drivers download.
Remove printer then added it again
Jan 02, 2010 | Brother MFC-465CN InkJet Printer
Brother mfc-465cn always restars
Not sure of the exact problem, but try a reset on it. Press Menu, *, 2, 8, 6, 4 within 2 seconds to get into service mode. Enter 91 to do a reset then 99 to exit. See if that helps and post here!
Nov 29, 2008 | Brother MFC-465CN InkJet Printer
My printer is "offline"
Try disabling the firewall, printing, re-enabling the firewall. My printer keeps working after re-enabling the firewall (at least for a while). Not ideal, but beats reinstalling the printer.
Mar 01, 2008 | Brother MultiFunction Center MFC-440CN...
Offline status
Under the control panel, click on the printer to bring up the print dialog. Go to printer at the top of page, drop down the menu and uncheck use printer off line. Should bring it on line.
Hope that helps
Oct 30, 2007 | Brother MFC-640CW All-In-One InkJet...
Brother MFC-465CN InkJet Printer Logo
566 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
