Question about ASUS P4P800SE Motherboard
Keyboard & Mouse
My mainboard is function but keyboard & mouse not function, but keyboard got on Num Lock
  • enterson1983 Sep 09, 2008
    but cannot function on keyboard & Mouse
    Sergeant:
  • 320 Answers
Make sure that the keyboard wire is plugged in to the keyboard port and mouse wire is plugged in to the mouse port. Remember that you need to restart the system once after you plugged into the motherboard. if that doesn't work then replace the keyboard / mouse and check. if same thing is happening then there is a problem in your motherboard. Thank you.
Posted on Sep 09, 2008
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
May 19, 2012 | Computers & Internet
On Saitek eclipse II illuminated keyboard: What is function of the 1 (above the f8), the A (aboveF9) and the down arrow between F10 and F11) Also the function of the dey on bottom row between the windows...
The 1, A and down arrow represent the usual Num Lock active, Caps Lock active and Scroll lock on option available on all keyboards out there.
The 'dey' key on the bottom between the Windows Key and the Ctrl acts as a right mouse button, as in opening the menu you would open with the right mouse click.
Hope it helps.
Dec 31, 2010 | Saitek Eclipse II Illuminated Keyboard
De activating num lock key only enables cursor movement in four directions. how do you get the number pad to enter numbers?
This is a Windows feature called "mouse keys", it can be disabled by using the shortcut left-alt+left-shift+num lock.
In Windows 7 mouse keys settings can be found by following Control Panel\All Control Panel Items\Ease of Access Center\Set up Mouse Keys
Nov 07, 2010 | Logitech Classic 200 DH968019 Keyboard
Cannot invoke hotkey function to switch computers .Directions say use num loc key plus minus key and release num loc but this doesnt work.
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, a much better hotkey for this switch is to tap scroll-lock twice. This automatically switches, so you don't have to hit multiple buttons.
Feb 18, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Aspire RC 500 - Acer w'less k'board & mouse packed up battery o.k
have you tried going into BIOS and setting Num Lock ON in startup? Do the Num Lock / Caps Lock and Scroll Lock flash when you boot up?
Check the pins if using PS/2 or is it a USB keyboard?
Cheers
Tim
Dec 12, 2007 | Acer Aspire L100 PC Desktop
Function key lock up
looks like a defective keyboard better return it
Sep 09, 2007 | Microsoft Wireless Laser Desktop 4000...
ASUS P4P800SE Motherboard Logo
134 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
