We have two Brother IntelliFax 4100 machines. They are used as standalone fax machines. We are not using the printer or copier features at all.
6 Months ago, one fax machine started faxing solid black pages. Reports print fine and there are no error messages, but the the receiver gets a full page of solid black.
I assumed it was just some bad error, but the second machine started doing the same exact thing.
Again, it prints fine and doesn't report any errors. The scan window is clean. Does anyone have any ideas? I found someone reporting a similar problem with a different model IntelliFax in Amazon.com reviews.
Comment by packfan77, posted on Mar 10, 2006
1 Other User Has The Same Problem
Comment by gquag, posted on Nov 29, 2007
I copy or send a fax and the right 5 or so lights on the scanner filcker. This in turn creates black horizontal lines on the right side of the page?? Can I reset the scanner? or do I need to replace it and how much? If this is even the prob.
Regards Geoff Q.
Was this solution helpful? Show your Appreciation by rating it:
http://support.microsoft.com/kb/q189764/
Rating: 0%, 0 votes
The second solution is to put the machine in maintenance and reset the scanner. Unplug the machine, put your finger on the menu key first and then re-plug the line while holding the menu key, in about 30 seconds all the lights will flash and the display will say maintenance. Release the menu Key and press 55 and this will reset the scanner; if scanner error comes up the machine will need to be serviced. Press stop and then 99 this will exit you out of maintenance. If the machine does not have an error try making a copy of blank sheet of paper and see if there is any improvement. As a routine clean the scanner glass with soft lint free cloth and isopropyl alcohol also.
Post a New problem for Brother IntelliFAX 4100 Plain Paper
Email this problem
Can you Help with these Fax Machines problems?
receiving multiple page fax on...
Brother Fax 4100e
Printer overlap
FUSER REPLACEMENT
