Question about Zenith C27A24T 27" TV
Broken RF Connector
I have a 27" Zennith tv and the rf connector(i guess, the cable jack that you plug the cable in to) on the back of my tv is broken off. Is there any way to fix and/or replace it?
  • davidsonmar Feb 24, 2009
    i have the same problum with my TV the whole RF jack came out nice and clean, is ther any way i can pop it back in without going to a repair shop. i triped over the cable wire and the RF jack got polled out.
  • 513 Answers
Its fixable. the question is how much of the inside broke with it. cost for repair on that usually averages 45 to 65 dollars... unless tuner is damaged in most cases not. if not hooked to tuner then maybe a new isolation block..simple job Good luck
Posted on Mar 14, 2006
Where to find a rf connector hp00351 for hitachi 50dx01b
I doubt that rf pack is available; a good idea might be to input signal to one of the sets of audio/video jacks via a cable box or even an old vcr to bypass a broken or defective connector.
Feb 05, 2012 | Hitachi 50DX01B 50" Rear Projection...
I have a Sanyo Tv model # SC31520 that dose not have a Cable jack on the back how do I hook it up to the Cable if it does not have a cable jack on the back
You will have to purchase cable that was once used to connect an older VCR to the TV. This cable connector will go into the RF connection of the TV to the RF connection on the cable box. If the RF connector you are looking for in the back of the TV is gone...you will have to find a TV tech to attach a new RF connection to the tuner of this TV. Hope this will help with a solution!
Feb 13, 2011 | Sanyo DS31520 31" TV
Cable in connector broken off
guess u mean the antenna in or also called rf. in this case if u are involved in electronics and have a soldering iron u can open the rf converter and solder a rf cable inside and leave it out the original hole and connect a simple plug for connecting to antenna. just ask again here to topic if something is unclear.
Feb 07, 2011 | Toshiba CF36H40 TV
Cable hookup broken
Sometimes you can replace the rf connector by resoldering it with a replacement rf. You will have to remove the tuner to do this. The big question is did you crack the tuner board or the board the tuner is connected to. You will really have to examine these. In most of my cases a successful replacement rf connector will fix.
Aug 24, 2009 | Sharp 27N-S300 TV
Cable female adaptor is missing
The small metal box is the tuner. The tuner has to be removed to replace the broken off RF connector. The connector has to be soldered to the tuner housing (metal box) and the leg of the connector has to be soldered to the circuit board, board has to be checked for cracks or if it is broken. If board is damaged the tuner will have to be replaced, if its available.
Aug 17, 2009 | Emerson EWF2703 27" TV
I cant get my dvd to play using my rf modulator
instead of plugging in the rf modulator before the cable box, i plugged it in after it
Jan 24, 2009 | GE 25GT240 25" TV
Broken RF Connector
you would have to get a new part for it. try looking online and out in your model number and put in rf connector needs replacing
Mar 10, 2008 | Apex Digital AT2002S 20" TV
Rf jack
You need an 800 degree soldering iron. It is advisable to tke this to a repair shop. A qualified echnician may bae able to repair the turner without further damaing. It is likely if you try to do this yourself the tuner will be damaged to the pint that it will have to be replaced which will mor than double your repair cost.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jul 31, 2007 | JVC AV-27260 27" TV
Zenith C27A24T 27" TV Logo
1,148 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
