Question about LG KU990 Viewty
Hard reset ipaq 111 running windows mobile verson 5.2
I am trying to perform hard reset, using the3 buttons(OK, stsem, rec) + soft - does not work. Removed the battery for 12 hours did not work either.
Any other ideas?
The main problem I am trying to solve is the "access denied" from windows mobile that does not let me delete any file.
Thanks!
YB.
    Problem Solver:
  • 16 Answers
just so you know, this is a LG KU990 forum.  these phone dont run windows mobile of any version.  I think there is a backup battery built into the phone.  Also, are you saying the hard reset 3 keys did not perfrom a hard reset or that the hard reset did not do annthing?
Posted on Oct 08, 2008
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
Itask button not responding & 5 way navigation will not scroll down when depressed
There are two things you can try:
1)remove the battery and reinstall it back
2)Go for a hard reset
Aug 05, 2008 | HP iPAQ RX3715 Pocket PC
Ipaq 111 hard reset
Soft reset Perform a soft reset
NOTE: Be sure to close all running applications before performing a soft reset.
To perform a soft reset:
1. Locate the recessed Reset button on the HP iPAQ.
2. Use the stylus to lightly press the Reset button.
Hard reset
To perform a hard reset and return the HP iPAQ to factory settings:
Press Win + OK + Record together.
While doing that, press reset button and hold for 3-4 seconds.
Release reset.
Release buttons.
NOTE: Do not release the buttons until CLEAN REBOOT appears on the screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | HP iPAQ 111 Classic Pocket PC
Im download app into my hp ipaq,then it hang/jam...it not running like usual..
For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
Solutions:
1. Soft Reset,
Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
2. Hard Reset
Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
settings.
NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
if you require more assistance feel free to reply to this post
Thanks for using FixYa
Regards-BA
Jan 27, 2011 | HP iPAQ 510 Voice Messenger Smartphone
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
How do i do a hard reset on HP ipaq X11-21204?
u have given a wrong Model number this is not a model number infact a part number pls try to find the correct model number from HP site thru photo identification if u dont find ur model other wise i am providing u detail below to try the hard reset on various series of HP IPAQS kindly be sure that ur ALL DATA WILL BE ERASED pls rate me FIXYA if i fixed ur problem
How to Perform a Hard Reset on an HP iPAQ
Performing a hard reset on an HP iPAQ is relatively easy, but is a dramatic step in the management of your handheld organizer. A hard reset will completely clear the memory of your device and restore it to the state you received it in from the factory. A soft reset, on the other hand, simply closes running programs and restarts your pocket PC.
Instructions
Difficulty: Moderately Easy
Step1
Read the owner’s manual. If you don’t have to do a hard reset, you shouldn’t, and you definitely don’t want to do one by accident. So familiarize yourself with the hard reset protocol offered in the manual.
Step2
Make sure you want to clear all personal settings, saved data and personal files from your PDA. If there are files you wish to retain, save them to a removable disk, or send them to your computer’s hard drive to be retrieved at a later date before performing a hard reset.
Step3
For the HP iPAQ h1900 series, hold down the power button while you use your stylus to hold down the reset button (on the left side of the iPAQ). Hold these buttons for a few seconds until the screen fades to black.
Step4
For the HP iPAQ h2000 Series, press down on the far left and right buttons (calendar and iTask, respectively). While you do this, press and hold the reset button on the back of the iPAQ until the screen fades.
Step5
For the HP iPAQ h5000 Series and H3800 Series, the procedure is the same as the h2000 Series with the only difference being on some models the Today button is used instead of the iTask button.
Step6
For the hw6500 Mobile Messenger Series and hx2000 Series the procedure for the hard reset is precisely the same as for the devices in step 4.
Step7
For the rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.
Step8
For the rz1710 and rz1715, follow the same procedure as the devices in step 7, with the difference of pressing the Today button (on the far right) instead of the iTask button.
Step9
To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Tips & Warnings
* If you’re iPAQ is simply slowing down or having problems, try a soft reset (reboot) before resorting to a hard reset.
* Read your iPAQ’s instruction manual to familiarize yourself with how to do a hard reset, and the effects of performing one.
* Do not perform a hard reset unless you are okay with or intend to erase all non-factory installed data and settings from your HP iPAQ.
Mar 17, 2009 | HP Computers & Internet
Memory on HP ipaq 114.
there are two types of memory my friend
1. RAM
2. ROM both built in PDA
third type is Storage Card u can store music and photos there but u cannot merge it with RAM or ROM so pls try to understand this difference
secondly if u want me to help u out on this memory shortage
then u can reset the device i mean hard reset and re install ur applications by time ur ROM is occupied by some useless files and ur performance is de graded try to refresh ur OS
Hard reset
HP iPAQ Setup Assistant
Use HP iPAQ Setup Assistant to simplify configuring settings on your HP iPAQ.
HP iPAQ Setup Assistant lets you save the settings on your computer. This can help you restore configuration settings on your HP iPAQ at any time. HP iPAQ Setup Assistant also allows you to perform a factory reset on your HP iPAQ and view detailed product information.
To hard reset HP iPAQ 114:
- press and hold the 3 buttons Windows, OK and REC
- press the reset button for about 3-4 seconds and release it
- release the 3 buttons
u can see the video for that but it is in russian lang but self explanatory
http://www.youtube.com/watch?v=BG68AzNBsds
third option is if u want to really get rid of this slow performance and shortage of space just get a clean CUSTOM ROM from
http://forum.xda-developers.com/ for ur PDA strictly at ur OWN RISK
pls rate me fixya if i have fixed ur problem
Mar 01, 2009 | HP Computers & Internet
Programs won't upload to my ipaq 111 classic ppc
I did not know that I needed to do a soft reboot on the PCC. Once that happened, everything loaded at once. I don't know where it came from, but it all loaded.
Dec 08, 2008 | HP iPAQ 111 Classic Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
The Pocket PC restarts and displays the Today screen.
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Oct 16, 2008 | Computers & Internet
Rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Nov 01, 2007 | HP iPAQ rx1950 Pocket PC
LG KU990 Viewty Logo
751 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
