Question about Creda W120VW Front Load Washer
Creda W120VW Intermittently not starting when door is closed.
In the last week or so, I've noticed my washing machine doesn't instantly start when the door is closed.
I have resorted to slamming the door up to 50 times before the washer will eventually fire up. When I'm slamming the door repeatedly I notice the odd flicker from the 'on' light, so it seems to be a case of keeping going with the slams until it starts the wash.
Is this likely to be a loose connection that I can fix myself?
Thanks in advance. Carole
  • Creda Master
  • 3,463 Answers
I don't know if you are still having a problem with your washer, but a new door lock is needed to put it right.
Posted on Nov 22, 2008
Dificulty starting machine
You need a new interlock ( its basically the electronic door catch easy to change)
Jun 26, 2014 | Creda W120VW Front Load Washer
How do i put door on again on creda excel 1200 as it has come off hinges
sounds like maybe you just sit the door on those pins and close it
Jun 04, 2014 | Creda W120VW Front Load Washer
Washing machine tripped ouy.
there is a track blowen on the programer thats has to be repaird fisrt if you can solder then get back to me ok
Nov 03, 2012 | Creda W120VW Front Load Washer
Creda excel W120VW the door lock light keeps flashing and cycle stops. If I hold the start button for a few seconds it starts again but then stops after about 2 mins.
From what you descibe it COULD be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 15, 2011 | Creda W120VW Front Load Washer
Manual for Creda Excel 1200 W120VW
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Thanks
Dec 15, 2008 | Creda W120VW Front Load Washer
Creda excel W120VW
the 3 things i would consider would be the interlock,on/off switch or timer, Just because the door clicks it does'nt mean the interlock is'nt faulty there is no test you can do to prove it apart from trying a new one. also the on/off switch can melt remove facia to gain access to the switch it will help if you also loosen the timer, which will also allow you to see if the timer has shorted where the black connector block on the top of the unit goes if there is a track blown you will need to change interlock aswell. GOOD LUCK
Aug 11, 2008 | Creda W120VW Front Load Washer
Rewiring Creda W120vw door
THEY ARE BOTH LIVE WIRES THE RED/GREEN ONE GOES NEAREST TO THE DOOR SEAL, AND AS I SAID THEY ARE BOTH LIVE SO PUTTING EITHER WAY WOULD NOT CAUSE A PROBLEM APART FROM ONE WAY THE MACHINE WOULD NOT WORK. I ASSUME THE BLACK WIRE IS ON THE MIDDLE CONNECTION, THIS IS NEUTRAL
Jul 15, 2008 | Creda W120VW Front Load Washer
Creda W120VW washing machine - Energy & Deep Rinse Buttons. How do they work?
I found the manual on a website which I didn't note down, but which was very useful as it had almost every washing machine manual on the planet! Now I know that the energay saving and deep rinsing buttons are activated by pressing them in. Thanks anyhow for your attempt to help!
Apr 24, 2008 | Creda W120VW Front Load Washer
Creda 1200 w220vw
Door lock light flashing is not normal, check to see if door is shut properly,another problem could be a track blown on control module, you would need to remove front console to check this.
Apr 17, 2008 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
180 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
