Question about Sony Ericsson Cell Phones
I CAN'T ANSWER MY PHONE BUS ICAN RING ALL THE PEOPLE
It could be that the answer /send key is at fault, you should try and activate to answer with any key.
Posted on Sep 09, 2008
When i press *#0011# it saw gsm limited, now ican chnge this
It is more then likely controlled by your phone provider thus is a question that their support line should be able to answer
Jun 24, 2014 | Samsung Galaxy S 4 GT-i9500 Smartphone...
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I have a Eurotel E1110 and don't know how to change the answer maching message, any clues?
i have a eurotel e1110 cordless home phone, ican any one help me, and let me know how to retrive my answer phone messages?
Mar 06, 2009 | Inter-Tel ECX 1000 Telephone
Sony ericsson 350i (using phone with flip closed)
under settings./calls ,scroll to bottom of page.answer on /off tab set to OFF you can use phone as normal then
Jan 18, 2009 | Lands Phones
I like to increase the ring volume of my samsung x820
press the button on the top left hand side of the set and you can change all tones.
Dec 02, 2008 | Samsung X820 Cellular Phone
Faxing
If you have a distinctive ring pattern activated in the same phone line you will be able to receive fax, Voicemal, and phone calls without disconnecting the fax cable on the All-In-One.
When you have activated a distictive ring pattern.
Then you need to set the rings to answer in your fax machine to The ring pattern which was provied by your telephone company.
In the Menu/Setup>Goto> Basic fax setup> Then> Set it to either double ring or triple ring which ever is aplicable. Then Raise the rings to answer in advance fax setup to 5 or 6 Rings
The rings to answer in you phone or answering machine should be set to 4 (Always lower then that of the fax)
Good Luck
Aug 25, 2008 | HP PSC 2210 All-In-One InkJet Printer
KDC-MP5039U - Bluetooth
yes u can ... all u need is a USB BLUETOOTH DEVICE ... plug it in ur panel and u can play songs from ur phone...answer and make calls etc
Jul 22, 2008 | Car Audio & Video
Caller Id not working, phone disconnects after 2nd ring
This problem turned out to be a phone company problem.
Jun 20, 2008 | Avaya Lands Phones
Cell Phones Logo
52 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
