Recording from Sky
My mother (83!) has just had Sky FreeSat installed. She has a Sanyo VCR and wants to know if she can record satellite programmes in addition to the usual 5 terrestrial channals. For example, to record something on BBC2, she would set the channel selector on the VCR to 2, press record and bobs-your-uncle. However, if she wants to record a programme on, say, channel 543 how can she do this?
If this is not going to be possible, would her problem be solved by changing to a DVD player instead?
  • Boolagh Sep 09, 2008
    Unfortunately, she can't afford Sky Plus. The VCR works fine recording from channels 1-5 but only accepts two digit channel codes so how can she record from three digit referenced channel?
    Sergeant:
    Champion:
  • 214 Answers
You need to connect the satellite box directly to the VCR and record
Posted on Sep 09, 2008
  • 19,396 Answers
Yes she ca record sat programmes on the VCR, all she need to do is connect video in into the VCR from sat box, or leave TV on while recoding, depending on the wiring settings.
  • 1 more comment
  • Ginko
    Ginko Sep 09, 2008
    The best option for recording from satellite, is asking sky the skybox with internal hard drive.
    In this way you do not use tapes or CD, but you record straight onto your Sky box Hard disk.
    To record on VCR you need to have following connection:
    From Sky box output >> VCR input
    From VCR >> TV input or scart
    If you use scart to connect VCR to TV, you can also record without connecting Sat to VCR.
    To get more details you can let me know what cables you use, how you plan to connect device, and post the models of Sat box, VCR and TV.
  • Ginko
    Ginko Sep 09, 2008
    You do not need two channels codes on VCR, VCR cannot be programmed on sat channels,
    all you do is connecting the sat box output to VCR, and VCR will see the SAT box as input, or line 1, or AV1, or external, or something similar, depending on the model.
    You cannot program VCR on sat channel, you will need to leave sat box on the channel you want to record, it will be the same on a DVD RW.
  • Ginko
    Ginko Sep 09, 2008
    Additionally, to make things clears, you can play VCR and DVD RW on tv channels 1-5 (in UK) because this devices have a built in TV receiver that can get regular tv aerial channels.
    Obviously VCR and DVD RW do not have a built in SAT receiver, therefore you cannot program recordings on channels from sat.
    You can only record from the channel that is currently been received on Sat, you can even use VCR timer, but you cannot store Sat channels into VCR.
I have a THS220 box and have difficulty recording programmes
Hello Joan,
To record a satellite you will need two scart leads.
Plug one end of the first scart lead into the "DVD/VCR SCART" socket on the back of the satellite receiver, then plug the other end into the "INPUT" scart on the back of the VCR. Take one end of the second scart lead and plug it into the "OUTPUT" socket on the back of the VCR and plug the other end into "SCART IN" socket on the back of the TV.
To record, select the satellite channel you want to record, then, on the VCR, select scart input, (at this point, you can record a satellite program). To watch a satellite channel or recorded satellite channel, select the scart input on the TV.
If you need anymore information, then let me know.
Kind regards,
Ron.
May 04, 2014 | Thomson Audio Players & Recorders
Playback of Topup TV Sky / ESPN Recordings
I am just guessing but you may have an ant-copy signal embedded into program signal causing to when you are trying to look at a recording to another source. If that is the case then there is one way that would work. You need to connect inline with the video line out to the in of the other unit (yellow) and that would solve the problem. Go to xdimax.com and check out a dimax signal adaptor( can not recall what it goes by,description-wise) This is almost like trying to use a hdmi output and a audio/video connection at the same time.This also happened when doing the same with some video decks (vcr)
Sep 02, 2017 | Thomson Televison & Video
How Tata sky HD superior than Tata sky?
Tata HD has clearer picture as it has high definition technology while Tata sky just has standard definition .
Regards
Mar 12, 2011 | Televison & Video
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
I have a toshiba rdxv60kb dvd recorder,,and can;t tune the programes into my sky box.
I have a toshiba Hdd & DVD / Video Recorder However I can not get it to work with my Sky setr up If I set thimer recording it does not work when I turn it on it will only work pn channels that are not from sky it will not instant record nor will it record programmes prerecoreded of sky HDD it will record everthing other than what I want.
My E-Mail Addres Is fj.gadkey_1@sky .com
My Home hone is uk 01527 545284
Nov 08, 2010 | Toshiba DVR660 DVD Recorder/VCR
Grundig GUFSDTR500HD FreeSat PVR Problem
Hi There, I've never had this problem with my Sky box, it knows which programs are repeats. I suspect its a problem with the GUFSDTR500HD. I have had two of these boxes from Costco, and both have both been as buggy as hell. They have recorded random programmes, they have missed recording programs, they often crash (black screen), series link seems to get it's knickers in a twist, and the up and down directional buttons fail to work after coming out of the guide or menu screen. To top it off, I found that the remote control also interferres with my B&Q fireplace... cycling through the colours when I change channel. Both of these boxes have gone back to Costco and I will never touch another Harvard Group (previously Alba, including Bush/Goodmans/Grundig) box again. Back to sky HD for me!
Feb 24, 2010 | Televison & Video
Can i set up my blu ray recorder DMR-BS750 without
The purpose of that freesat to bo able to record/playbak 2 channels at the same time. But you still need a satellite dish pointing to the satellite in the sky so it can work.
Jan 13, 2010 | Panasonic Televison & Video
What program nuber to use when setting up recording from Sky box connected to AV2?
Connect a scart lead from the sky box into av2 scart socket on you vcr,then select av2 on the vcr as your record channel
May 10, 2009 | Philips VR620CAT VCR
New sky digibox fitted. Cannot timer record satellite programmes
I encountered a similar problem when recording and I phoned Sky and they changed my settings to eliminate standby mode for me.
No problem any more.
Mar 21, 2009 | Panasonic Televison & Video
Connect a dvd-vcr recorder to my tb
you will need an external dvd recorder to record vcr tapes to dvd. Sometimes you will have problems with quality when you do it this way. I have transfered vcr tapes to dvd with a transfer device using the computer and got much better results. If you need the name of the transfer device just get back with me and I will get it for you.
Feb 11, 2009 | Sanyo DS27510 27" TV
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
