HP2575 file HPZius12.sys' cannot find on HP CD. When I turn printer on it keeps telling me to look for it. Also printer download has overwritten my Verbatim memory stick files what do I do Margaret
  • David_25 Sep 10, 2008
    I have a Deskjet 5600, but I can instal all the drivers, The same error: file HPZius12.sys' cannot find.
    Where I can get this file?
    Thanks.
  • Anonymous Apr 24, 2009
    I have the same problem with an inkjet printer for HP: HPZius12.sys on hp cd is needed :O
  • 16 Answers
Hope this helps everyone find
HPZIUS12.sys:
http://www.mediafire.com/?sharekey=e9aadae9e125dc63d2db6fb9a8902bda
I uploaded it to media fire from my original disk; I'm not sure why the new installers ask for it.
Posted on Sep 12, 2009
  • Bunny Osterhout
    Bunny Osterhout Jun 24, 2012
    this folder no longer exists!! please help?? thanks!!
I have purchased a recycled HP laserjet 2420n with no CD. I did the plug and play and my PC recognises that it is there but then asks me for the HPPaufd0.sys file. I have searched for it. I have gone...
You will need to download the correct driver for your OS from this HP website. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=412129&taskId=135&prodTypeId=18972&prodSeriesId=416419&lang=en&cc=us
Install the driver and plug the printer back in. It will now find the new driver and will have all the support files as well.
If you continue to have issues, temporarily disable your viruses scanner while you install the driver. The drivers from HP's website contain no viruses so your scanner may give a false positive if it tries to remove any files while installing.
Regards, Chris
Aug 30, 2011 | HP LaserJet 2420 Printer
During printer installation there is a message content: HPZius12.sys needed but it not find on recpective installation cd,pls help me
HPZius12.sys is Hewlett Packard printer driver system driver file. To fix the issue, it is recommended that you download the latest up-to-date drivers from HP Official for your Product and install them.
Let me know if any further clarification/ assistance is required.
Hope this helps!
CreativeTECH
Dec 31, 2010 | Office Equipment & Supplies
I keep getting an error when I try to load HP Deskjet 1432 Printer. It tells me it needs a certain file to load ICM.RBG... (might not be the exact name of the file needed....but it does start with ICM.
Awhile back I had the same exact problem.
First search the the installation cd for that file it wants.
Copy it to your hard drive. Suggest a directory that is simple and easy to find. Like C:\HP Drivers
Now when it asks for that file, point it at C:\HP Drivers or whatever you have choosen. Be prepared to look for more files, this is usually the result of a flaky installation program or CD.
You could also try downloading the latest installation file with updated drivers. This will often fix the problem. Be SURE to turn off any virus detection or spyware program. This is ONLY while installing the software. Virus detector's and Spyware applications can and will muck up an installation of software. Be sure to turn these back on AFTER you install drivers or applications.
Hope this Helps!
Nov 23, 2009 | HP Officejet 4355 All-In-One InkJet...
Cannot scan a file to a Pdf file on 64-bit Vista.
Try this:
First put the cd and installation wizard will come up ...goto install more sw>>install ocr .....
Now scan will get the options.
or
Now for the 2nd opt>> put the sw cd if you have right click explore ..(goto step 3) but if you dont have the cd you can download the sw from hp.com >support and drivers..extract the file and goto run(search bar for vista) type "%temp%" and then click on folder starting with 7z....now goto step 3.
step 3.goto util folder>>ccc>>unistall l3 but make sure you have to unplug the usb first.
>>Small black box will appear and press enter...and wait it will unistal the printer sw.
>>goto printers and faxes folder under controlpanel (printer for vista)...chk if there is any hp printer any more...if there is any printer not in use..delete them.
>>restart the sys and then install from the downloaded sw only but make sure you should include ocr sw if you are installing it as a custom installtion other wise everything fine.
now scan everything will work.
let me know.
Best wishes,
Suvrajit
Apr 10, 2009 | HP LaserJet 3015 All-In-One Printer
Connect HP 3015 all in one printer to Aspire One
Disconnect the printer from your computer. Go to Start -> Control Panel -> Printers. Right-click on the HP 3015 printer and select Delete. Confirm the deletion of the printer. If it asks about removing unused driver files, answer Yes. Reinstall the driver files using the provided setup program. Do NOT use the Add printer... dialogs. If the installation program prompts you to plug in and turn on the printer then do so, but do not do this before it prompts you. This is what generally causes the missing files problem. If it goes completely through the installation without telling you to plug in the printer (which would be unusual for HP printers), plug it in when it completes. It should automatically recognize the printer being plugged in (and turned on, if necessary) and then finalize the driver configuration.
Mar 18, 2009 | Acer Aspire One PC Notebook
Installation disc for hp2575 will not install on windows vista
Go to the following site, select your operating system, and download a new version here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441240&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%C2%BB
*please rate me :)
Mar 14, 2009 | HP Photosmart 2575 All-In-One InkJet...
Install HP Deskjet 3920 printer
Here is download page from HP
HP Deskjet 3920 Printer - Download drivers
Chose language and OS version. After downloading the file, double click on the downloaded file to start printer setup wizard.
Keep printer unplugged when you start installing files.
Sep 03, 2008 | HP DeskJet 3930 InkJet Printer
Does HP2575 read SDHC SD cards
HP2575 doesn't read SDHC cards. You can only read SDHC cards in devices approved for SDHC use.
Aug 13, 2008 | HP Office Equipment & Supplies
3,585 people viewed this question
jasbo
jasbo
