Question about Zenith VRA421 VHS VCR
Can hear crackling or spitting sound when selecting HI-FI
When I select HI-FI instead of standard in the Audio Menu. I then play any HI-FI video cassette, and I hear a crackling sound when the tape plays in the background. Sound comes off the speakers, not the VCR itself. Sound is present whether there is sound on the cassette, or a silent scene in a movie. It seems like a distortion of sorts. Sound is not present when I select STANDARD AUDIO in the audio menu. What could it possibly be? I adjusted the internal pots, but to no avail. Any suggestions at where to look. I have also tried multiple cables, different TVs.
    Problem Solver:
Could be alignment or one of the hi fi head not reading properly.I other words you have to change the upper cylinder.
Nuch
Posted on Dec 21, 2007
  • 513 Answers
The "crackling" sound you describe sounds suspiciously like mis-tracking. That is: The result of the Hi-Fi heads (which are on the rotating video headwheel or drum) not exactly following the recorded tracks. Have you tried adjusting the tracking slightly? The reason this happens is that the Hi-Fi tracks are MUCH narrower than the thinnest video track (used for 6 hours per T120 tape). Tape stretches and shrinks as it ages. Video recorders wear with normal use in such a way that the tracking changes. The problem is often worse with tapes recorded at the SLP (6 hour) speed because the servo cannot correct errors as fast when the tape is moving slowly (on some machines only). Tape quality also counts...and manufacturers change their formulations without public notice. All these things can lead to "archived" tapes being lost. Solution: Use the best quality tape you can afford, not the cheapest; record at the highest possible speed. Store the tape carefully. Never use a cheap "rewinder" because they can over-tighten the tape causing wrinkles, stretches, and other kinds of damage.
Posted on Mar 14, 2006
4 Suggested Answers
SOURCE:
  • 979 Answers
SOURCE: Only plays picture when fast forward.
Cleaning or video head replacement time....accordianman
Posted on Feb 15, 2008
SOURCE: ZENITH VCR TAPE KEEPS EJECTING
Happened to me last nite wi 2 old tapes - the end of the tape came off the right wheel when it rewound - that was the cause - look up how to fix tapes by taking the casette apart - only thing I cant find is a picture of how the tape will feed between the heads inside he case since i suspect the tape will have fully rewound
Posted on May 26, 2008
rapanSF
  • 150 Answers
SOURCE: When playing back a recorded program only get sound. No picture
Either the program is copy protected or connection to TV is mismatched.
Posted on Mar 25, 2009
What do I need for my vizio TV and JVC receiver to
A standard RCA cable audio out of the tv to audio input of the receiver(ie, tv in or auxillary in (select which input you used on the reciever menu) The sound from the tv will be played through the receiver.
Oct 06, 2014 | Audio Players & Recorders
Playing a blu ray disk on PS3 connected with optical cable to the Onkyo, I only get a PCM signal, no DTS or 5.1 (although this is available on the BD)
In theory, your receiver's decoder should be able to automatically "detect" the incoming audio format. But, this only occurs if the device playing the disc is sending the correct audio format.
So, with this said, there should be a fun tion on your PS3 where you can manually select either Dolby 5.1 or DTS 5.1. Both of these are opposing formats (i.e. can only output one format at a time).
If you were to play a movie disc from a standard DVD player into your Onkyo receiver, you would normally have to manually select DTS 5.1 audio from the disc menu.
Does the PS3 menu allow you to manually select the audio output?
Sep 05, 2011 | Onkyo TX-DS696 Receiver
I AHVE A HD PHILIPS TV ,IHAVE ABSOLUTLEY NO SOUND ON THE STANDARD TV ,I ONLYHAVE SOUND IF I PLAY A DVD MOVIE. RIGHT NOW THE SUPERBOWL IS ON AND I CANT HEAR A THING.PLEASEHELP.
when you play a dvd, do you have to select aux, or video channel to play this ? if so select tv on your remote, not a solution, just an idea.
Feb 08, 2010 | Car Audio & Video
No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Jun 12, 2009 | Onkyo TX-DS696 Receiver
My PS3 will not play sounds on games. I have reset the sound settings to output HDMI and I can hear the click when I move around the setting screen. I can also hear the playstation 3 startup but no sound...
1. In the PS3's XMB, go to the left and select Settings.
2. In Settings, go into SoundSettings.
3. Select Audio Output Settings, and select the type of cable you use.
4. The next page will give you an option for Automatic or Manual. Select Manual.
5. The next page will give you a list of all the audio settings the PS3 can output. Unselect every option except the ones grayed out, which are required.
6. The next page will ask you to confirm the selections, say yes.
7. (OPTIONAL) For those using HDMI cables, now that we have set them to default settings, we can actually start the process over again, but instead of selecting Manual we will select Automatic. This will force the PS3 to scan the devices again and set up the correct list of output modes.
Jan 06, 2018 | Sony PlayStation® 3 (60 GB) Console
PS3 hdmi Audio problem Crackling Sounds
I CHANGED THE AUDIO SETTING UNDER HDMI FROM AUTO TO MANUAL AND I REMOVED DOLBY 5.1 FROM SELECTIONS.LEFT THE OTHER 2 SELECTIONS THAT WERE ALREADY SELECTED FROM AUTO SET FOR HDMI I HAVE NOT HAD AUDIO PROBLEMS SINCE.
Nov 05, 2008 | Sony Playstation 3 (PS3) Console
How do i bypass the parking brake switch in order for my video to play
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
Feb 18, 2008 | Dual XDVD8181 Car Video Player
Loud static
Verify that your microphone is configured correctly loadTOCNode(2, 'resolution'); 1. In Windows Live Messenger, if you cannot see the menu, click Show Menu. 2. On the Tools menu, click Audio and Video Setup. 3. Click Next two times. On the Microphone page, verify that the correct microphone is selected on the Select the microphone you would like to use drop-down list. Speak in a typical tone of voice, and then verify that the voice meter moves up and down correctly. 4. Click Next, and then click Finish.uparrow.gifBack to the top
Verify that your contact's speakers are working correctly loadTOCNode(2, 'resolution'); To do this, have your contact follow these steps: 1. In Windows Live Messenger, if you cannot see the menu, click Show Menu. 2. On the Tools menu, click Audio and Video Setup. 3. Click Next. On the Speakers page, verify that the correct sound system is selected on the Select the speakers or headset you would like to use drop-down list. 4. Click Play Sound, and then verify that you hear the sounds correctly. 5. Click Stop Sound. 6. Click Next two times, and then click Finish.
Jan 02, 2008 | Microsoft LifeCam VX-3000 Web Camera
Go to audio options, and manually DE-select Digital 5.1. That should fix it. It did for me.
Aug 28, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
323 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
