Question about Hoover Washing Machines
Hoover HW5513M cuts out the main RCD trip during a wash program
    President:
  • 1,462 Answers
Take back off and check heater for faulty to earth. one way is to disconnect heater, run machine and see if fault has gone
Posted on Sep 09, 2008
My hoover optima washing machine is tripping my electricity supply. Have tried disconnecting heating element and looking for damaged wires.
Ian if the circuit breaker is a rcd it will trip off the supply if it
normally detects a very small leakage or unbalance of around 35 m /amps this could be a small water leak onto live parts in the machine or a minute short to earth on one component ,make sure all parts are dry / is it tripping when you switch power on to machine or does it trip when machine is in cycle mode.
1. its as first suggestion 2. it's a component like pump or drive motor that;s causing problem. hope this is of some help,g.luck
Nov 11, 2016 | Hoover Washing Machines
Machine cutting out and blowing fuse
if its the rcd tripped in mains then you have a current leak to earth. means water or steam has tripped . u need to find source in washing machine, often the heating element or thermostat..u could look for free service manual at manualslib ManualsLib Makes it easy to find manuals online
Jul 14, 2014 | Siemens Washing Machines
HOOVER HNF 7147. BLOWS THE HOUSE RCD ONLY WHEN ON A WASH CYCLE AND NO WATER BEING FED INTO DRUM. I SUSPECT THE HEATING ELEMENT IS DRAWING TOO MUCH DUE TO NO WATER IN THE DRUM. BOTH INLET VALVES ARE OK AS I...
You need to check the circuit in the wash cycle. Disconnect the power to the heater coils and see if the fuse trips. Also the voltage at inlet solenoid must be checked when the program cycle is on the wash , is not the program controller board is fault, possible a wrong output from the processor.
You can isolate the circuits, the heater, the motor drive to see if the trip stays. Also check the inlet and the drain pump on a test bench to confirm the working of the valve which will infer the case.
Sep 16, 2011 | Hoover Washing Machines
Condensation builds up inside machine during cycle and trips out the electric
i cant see condensation being the problem. as washers are designed to withhold this factor i belive there is an earthing problem or/ pos/neg leak causing the washer to trip the rcd. have it looked at by a service tech
best of luck
Nov 28, 2010 | Hoover HW130M Front Load Washer / Dryer
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Jul 30, 2009 | Washing Machines
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Washing Machines Logo
117 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
