Question about Sony Audio Players & Recorders
I have an 8 year old tower system which has suddenly shown push power protect when i want to play anything model no lbthb500
    Problem Solver:
  • 11 Answers
Hi i have the same model and had the same problem in the past i found that two speaker wires were toching each other i seperated them and now my set works fine try this out if no luck then make sure all your audio connections in the back of ur hi-fi are connected properly
Posted on Sep 11, 2008
Push power protect
Most likely you shorted out the amp ic. This will need to be replaced before the unit can be used again.
Jan 06, 2013 | Audio Players & Recorders
Philips DCB146 NO SOUND!!
The answer is straightforward. The main power amp has gone. If you are lucky it's a single IC unit which you will find on a big heat sink. It might look like the one shown below.
You will of course need to de-solder it and resolder a new one. The type needed to replace it will be shown by the letters and number on the IC itself.
May 02, 2017 | Audio Players & Recorders
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
"Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
May 02, 2009 | Sony Audio Players & Recorders
It says push power protector on my new sony surround system i cant do anything with it
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Apr 17, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Kenwood XD V757 System Protected
check the speaker wires are not shorting out
Dec 11, 2008 | Audio Players & Recorders
Protect push power
hi, everytime i switch on my sony hi fi it the display screen says protect push power. It won't let me do anything not even put cd's in. If you could help that would be very much appreciated.
Jun 12, 2008 | Sony LBT-XGR6 CD Shelf System
PROTECT PUSH POWER IT KEEP SAYING WHAT TO DO
My Sony audio set keeps saying push power protect and the set freezes what should i do? Please help me solve this problem.
Apr 20, 2008 | Sony LBT-XGR6 CD Shelf System
System won't let me play anything
You need to replace the audio amplifier IC because are damaged
Jan 16, 2007 | Sony LBT-W900AV Shelf System
87 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
